Changing standard error to standard deviation.
To convert standard error to standard deviation, the correct formula is STD ERROR = STD DEV / (n^0.5), where n represents the sample size. The discussion clarifies that degrees of freedom, defined as N minus the number of X coefficients, is not necessary for this conversion. Additionally, the formula for standard deviation is mentioned as STD DEV = SUM OF SQUARES / ((n-1)^0.5). There is caution against using "degrees of freedom" in this context, as it applies specifically to statistical tests and differs from sample size. Understanding these distinctions is crucial for accurate statistical analysis.
operationsres
Hi all,
I've done a regression and have the Standard Error of the X co-efficient (i.e. the slope).
How do I change this figure to the standard deviation?
Is the formula
STD DEV = (STD ERROR)/(degrees of freedom)^0.5
Where degrees of freedom = N - number of X coefficients.
Thanks.
Actually, I believe the formula is STD ERROR = STD DEV / (n^0.5)
Moreover:
I'm reluctant to use the term "degrees of freedom" because this measure doesn't come into play unless a statistical test is involved, and is not the same as the sample size, "n."
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
