Changing the direction of light
  • Thread starter Thread starter adn
    Direction Light
A magnetic field can influence the direction of light when it interacts with a medium like plasma, altering the index of refraction. This effect is utilized in magneto-optic materials, which can change the polarization of electromagnetic waves. However, a magnetic field alone does not change light's direction according to classical Maxwell's equations. The interaction with other materials that respond to magnetic fields introduces different mechanisms. Understanding these principles is crucial for applications in optics and photonics.
adn
Hi,
Can a magnet change the direction of light (generally, photon or maybe electromagnetic wave)? _if yes, how? _
--adn
Science news on Phys.org
A magnetic field can change the direction of light propagtion - if it's in a medium such as plasma. In effect, the index of refraction is changed by the magnetic field.
Magneto-optic materials can change the polarisation of an EM waves, which can - using other polarisation dependant optics (such as a birefringent crystal) change the direction of propagation of an em wave.
Claude.
Be very careful with the two answers given above. A magnetic field, by itself, has no ability to change the direction of light based on the classical Maxwell Equation. The presence of another material that changes its properties due to a magnetic field has a whole different set of mechanism involved.
Zz.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
