I Characteristic curves for ##u_t + (1-2u)u_x = -1/4, u(x,0) = f(x)##
BloonAinte
TL;DR Summary
Characteristic curves for ##u_t + (1-2u)u_x = -1/4, u(x,0) = f(x)## where ##f(x) = \begin{cases} \frac{1}{4} & x > 0 \\ \frac{3}{4} & x < 0 \end{cases}##
I woud like to find the characteristic curves for ##u_t + (1-2u)u_x = -1/4, u(x,0) = f(x)## where ##f(x) = \begin{cases} \frac{1}{4} & x > 0 \\ \frac{3}{4} & x < 0 \end{cases}##.
By using the method of chacteristics, I obtain the Charpit-Lagrange system of ODEs: ##dt/ds = 1##, ##dx/ds = 1 - 2u##, ##du/ds = -1/4##. I then solve to get ##t = s##, ##u = - 1/4t + \xi##, and ##x = t + t^2/4 - 2tf(\xi) + \xi##. I then rearrange and use the quadratic formula to get $$t = -2a \pm \sqrt{4a^2 - 4(\xi - x)}$$ where ##a = 1-2f(\xi) = \begin{cases} \frac{1}{2} & \xi > 0 \\ -\frac{1}{2} & \xi < 0 \end{cases}##. I think that this is correct so far. However, I am unsure on how to select the square roots appropriately. I would be grateful for any help! Thank you for your time.
I'm not sure why you need to do that. The characteristics are curves in the (x,t) plane, or more properly the half-plane t &gt; 0. If you're having difficulty expressing them in the form t(x), then use x(t), which you already have.
You can see that the characteristics are x = \frac14t^2 - \frac12t + \xi for \xi &lt; 0 and x = \frac14t^2 + \frac12t + \xi for \xi &gt; 0. This gives you three regions of the half-plane:
(1) For x &lt; \frac14t^2 - \frac12t, \xi &lt; 0 so u(x,t) = (3 - t)/4.
(2) For x &gt; \frac14t^2 + \frac12t, \xi &gt; 0 so u(x,t) = (1 - t)/4.
(3) For \frac14t^2 - \frac12t &lt; x &lt; \frac14t^2 + \frac12t we are between two characteristics which both have \xi = 0; in this region we have an expansion fan.
Likes BloonAinte and fresh_42
Thank you so much!
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
