Characterizing Possible Sequences for Forests | Graph Theory Homework Question
roadrunner
Characterize all possible sequences d1; d2; : : : ; dn so that there exists a forest
with vertex set fv1; v2; : : : vng with deg(vi) = di. (So, you should nd a statement of the
form: a sequence d1; : : : dn comes from a forest if and only if ... )
I emailed him and asked...he said this
In the last homework, you proved that a sequence d1, d2, .. dn is the
degree sequence of a tree if and only if d1..dn are positive integers
and they sum to 2n-2.
I want you to prove a similar thing for forests. So you should show that
a sequence d1, d2, .. dn is the degree sequence of a tree if and only if
Not too sure what I need to do?
bump?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
