Charged Teflon Rod & Aluminum (Conductor vs Insulator type question)
The discussion revolves around the interaction between a negatively charged Teflon rod and an initially neutral aluminum rod after contact. The Teflon rod retains a net negative charge due to its insulating properties, while the aluminum rod becomes negatively charged after receiving some electrons. When the Teflon rod is brought near the aluminum rod without touching, they attract each other because the electrons in the aluminum redistribute, creating a positive charge at the end closest to the Teflon. This attraction occurs despite both rods being negatively charged overall. The reasoning is confirmed as correct, highlighting the behavior of charges in conductive and insulating materials.
SMA777
Hello,
Just wanted to check my some of my reasoning to these. If anyone could confirm if these answer I got are right (or point me in the right direction if they aren't!) I'd really appreciate that. Thanks!
1. Homework Statement
(No Relevant Equations, real, & Attempts at Solutions are Italicized)
Suppose a student rubbed a Teflon rod with wool then briefly touched it to an initially neutral aluminum rod suspended by insulating threads.
What would the net charge on the Teflon rod be?
I said the net charge on it would be NEGATIVE because it becomes negatively charged due to being rubbed with the wool, and while some of the electrons escape when touched to the aluminum, not all of them do because teflon is an insulator so within the teflon rod itself, they couldn't move closer to the aluminum point-of-contact to escape
What would the net charge on the aluminum rod be?
I said the net charge on the aluminum rod would also be NEGATIVE because it received some electrons from the point of contact with the Teflon rod
The student then holds the Teflon rod near the aluminum rod, but does not allow them to touch. The student observes that when the rods are close enough together, they attract. Explain why the rods are attracting each other.
I said they are attracting because the point of contact on the Teflon now doesn't have electrons because they were able to leave and transfer to the aluminum (making that point positively charged). So now, when that rod's point of contact is brought near the negatively charged aluminum, they attract each other, despite both rods having overall negative charges
...any faulty reasoning, or does this look good? Thanks for any feedback!
SMA777 said:
Hello,
Hello SMA777. Welcome to PF !
It's good down to here.
The Teflon won't become positively charged, even at the point of contact.
What will be the behavior of the charges on the aluminum rod as the Teflon rod gets very close?
You are right, the rods will attract each other. Think: Would they attract if the Teflon rod had not touched the aluminium before?
You know that aluminium is a metal, it has mobile free electrons. What happens with these electrons when the aluminium rod is close to a negatively charged object?
ehild
Oh! Got it, so, I believe this is now correct:
the electrons in the aluminum rod consolidate near the end away from the teflon rod, which they can do so because aluminum is a conductor (and they want to because both the aluminum and teflon are negatively charged, thus repelling each other). This leaves the positive charge in the aluminum rod near the end close to the teflon, causing an attraction of that positive end of the aluminum rod to the negatively charged teflon rod.
Thank you both so much for your help!
That is correct now! ehild
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
