Charging voltage versus battery voltage
In summary, during charging the potential difference between the terminals of a battery becomes greater than the electromotive force in order to reverse the chemical reaction that produces the EMF. This is achieved by applying a greater voltage from an external source. However, the charge voltage must be limited to prevent excessive heat generation which can damage the battery. Different types of batteries require different charging methods and have different limitations on the charge voltage and current.
moatasim23
78
Why during charging a battery the terminal Potential Difference becomes greater than the EMF?
I believe it has to in order to reverse the chemical reaction that produces the EMF in the first place.
Well to be more specified.I wanted to ask HOW..
How what? Please be specific when posting questions, or you will confuse people, and more importantly you will confuse me! :biggrin:
Sorry for inconvenience...I wanted to ask:
How the potential difference becomes greater than EMF?
I think the charger is simply set up to apply a greater voltage than the battery produces.
Hi moatasim:)...IN the start you can't roughly say t.p.d will be greater than emf during charging.when u begin charging, the terminal p.d simply increases coz of the incoming positive charges from other source.charge accumulation leads to greater increase in potential difference(as Q is directly related to V). when charge accumulation goes on increasing then incoming positive charge from external source towards negative plate of cell(under charge) will be attracted towards it more strongly and when it reaches negative plate then it is pushed towards positive plate due to increasingly potential difference.as emf is the push of positive charge from negative to positive terminal,then with da increase in time this push becomes more and more ease and less emf though will be due to a p.d cloud.NOW,as you know emf exists even there's no current in circuit and p.d don't exist if there's no current.In start when charging begins,p.d goes on increasing but still be less than emf already present.SO in beginning and till to a particular time t.p.d will be less than emf. MATHEMATICALLY FOR DISCHARGING
t.p.d = E - Ir
V= E - Ir ( E is the electromotive force)
or E=V + Ir ( V is t.p.d)
FOR CHARGING
v = E + Ir (as for charging respective electrodes are alike)
E= V-Ir SO you can clearly see emf decreses by a function of time Q/t.( Ir=Q/t*r) with the passage of time E goes on decreasing and consequently V goes on increasing..I hope you will get it:)
t.p.d = E - Ir
FOR CHARGING
The model for most batteries is of an "ideal" voltage source in series with a resistor. It's that resistor that you need to consider.
* ideal means whatever you need it to, here. :smile:
Batteries produce power via chemical reactions...charging reverses those...the higher the charge voltage the higher the current flow and the faster the reverse chemical reaction.
BUT higher currents [via higher charge voltages] mean more heat and that can ruin batteries...so charge voltages must be limited...
An AGM battery can be charged at it full rated amp hour capacity because it has very low internal resistance, so not much heat is generated during charging, not so for a traditional wet cell lead acid battery which is limited to about 25%. These mean for a battery rated at, say, 100 amp hours, you can safely charge an AGM at 100 amps but a conventional battery at only about 25 amps. In a conventional wet cell lead acid battery about a quarter of the charge power is lost thru heating, only 1 or 2% is lost to heat in an AGM type battery. .
FAQ: Charging voltage versus battery voltage
What is the difference between charging voltage and battery voltage?
The charging voltage refers to the amount of electrical energy supplied to a battery to recharge it, while the battery voltage is the amount of electrical energy stored in the battery. Essentially, charging voltage is the input and battery voltage is the output.
How does the charging voltage affect the battery's performance?
The charging voltage is crucial for maintaining a healthy battery and ensuring it performs optimally. If the charging voltage is too low, the battery may not fully charge, leading to reduced battery life and capacity. On the other hand, if the charging voltage is too high, it can damage the battery and shorten its lifespan.
What is the ideal charging voltage for a battery?
The ideal charging voltage varies depending on the type of battery. Generally, lead-acid batteries have a charging voltage of around 2.3-2.4 volts per cell, while lithium-ion batteries have a charging voltage of 4.2 volts per cell. It is important to follow the manufacturer's recommendations for the specific battery being used.
Can I use a higher voltage charger to charge my battery faster?
No, using a higher voltage charger than recommended can be dangerous and potentially damage the battery. It is important to use the correct charging voltage to ensure the battery is charged safely and efficiently.
Why does the charging voltage increase as the battery charges?
As the battery charges, its internal resistance increases, which means it requires a higher voltage to keep charging at the same rate. This is why the charging voltage gradually increases as the battery reaches a full charge.
