MHB Charlene's question at Yahoo Answers regarding related rates
  • Thread starter Thread starter MarkFL
    Related rates
The discussion focuses on calculating the rate of change of the angle theta as an airplane flies at a constant altitude of 8 miles and a speed of 450 mph. The relationship between the angle, altitude, and distance from the radar is established using the tangent function. By differentiating the tangent function with respect to time, the formula for the rate of change of theta is derived as |dθ/dt| = hv/s². Substituting the given values of altitude, speed, and distance results in a final calculation of |dθ/dt| = 144/25 radians per hour. This provides a clear solution to Charlene's question regarding the rate of change of theta.
MarkFL
MHB
Here is the question:
Rate of change of theta?
An airplane is flying at a constant altitude of 8 miles over a radar at a rate of 450mph. At what rate is the angle theta changing when s=25?
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello Charlene,
I would first draw a diagram to represent the problem. I will assume the quantity $s$ represents the distance from the radar station directly to the plane. $R$ represents the location of the radar station, and $P$ the location of the plane. I have let $h$ represent the constant altitude of the plane. All linear measures are in miles.
Since we are given:
(1) $$\left|\frac{dx}{dt} \right|=v\,\therefore\,\frac{dx}{dt}=\pm v$$
where $v$ is the speed of the plane, and we know $h$, we want to relate $\theta$, $x$ and $h$. We may do so by using the definition of the tangent function as follows:
$$\tan(\theta)=\frac{h}{x}$$
Now, implicitly differentiating with respect to time $t$, we obtain:
$$\sec^2(\theta)\frac{d\theta}{dt}=-\frac{h}{x^2}\cdot\frac{dx}{dt}$$
Multiplying through by $$\cos^2(\theta)$$ and using (1) we have:
$$\frac{d\theta}{dt}=\pm\frac{hv\cos^2(\theta)}{x^2}$$
Now, from our diagram, we see that:
$$\cos(\theta)=\frac{x}{s}$$
and so we find:
$$\frac{d\theta}{dt}=\pm\frac{hv\left(\frac{x}{s} \right)^2}{x^2}=\pm\frac{hv}{s^2}$$
As we are only asked for the magnitude of the rate of change in $\theta$ with respect to time, we may write:
$$\left|\frac{d\theta}{dt} \right|=\frac{hv}{s^2}$$
Now, using the given data:
$$h=8,\,v=450,\,s=25$$
we find, in radians per hour:
$$\left|\frac{d\theta}{dt} \right|=\frac{8\cdot450}{25^2}=\frac{144}{25}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
