Cheapest equipment to boil water at 60℃
In summary, water in a closed container boils at 60℃ when the vapor pressure of water is equal to the surrounding pressure. To demonstrate this principle at home, one can use a glass container, a beaker of water at 60℃, a thermometer, an electric vacuum pump, and a lid sealed with a sealant like M-seal. The pump should be operated to create a partial vacuum, and the water will boil at 60℃. One can also use a vacuum chamber kit or a hypodermic syringe to create a similar setup. It is important to avoid exceeding 100℃ to prevent potential danger. Adding heat can help maintain the temperature and keep the water boiling. A heated water bath can
KedarMhaswade
35
TL;DR Summary
How do we create a partial vacuum to boil water at about 60℃?
Water (any liquid) in a closed container boils when the vapor pressure of water (a property that depends on its temperature) equals the surrounding pressure. The vapor pressure of water at 60℃ is about ##1.99\times10^{4}## which is roughly 150 mm Hg.This principle is so simple, and yet, it is rather difficult to demonstrate effectively at home (with cheap equipment the links to which I have posted to below). I have thought of doing this experiment in the following (perhaps simplistic) manner (see the Figure).
  1. Take a glass container and place a beaker of water at about 60℃ in it.
  2. Insert a thermometer and an electric vacuum pump in a lid and seal that lid to the container with some sealant like M-seal.
  3. Operate the pump to create partial vacuum.
I'd like the kids to see the water boil at about 60℃. My questions:
  1. I believe it should work, but are there any obvious flaws in my setup?
  2. Any tips to maximize the probability of success?
The "Vacuum Chamber Stainless Steel Kit" used for Degassing Urethane are listed on eBay.
They have a thick clear lid. Check they will operate at 70 deg C, and include a vacuum pump.
Likes KedarMhaswade
Being the world's biggest cheapskate, I would recommend a hypodermic syringe. Here's the video that came up first when I googled:
These are called "flavor injectors" at the local grocery store I shop at. They cost about $5.
Likes russ_watters, Drakkith, KedarMhaswade and 1 other person
KedarMhaswade said:
Summary:: How do we create a partial vacuum to boil water at about 60℃?
Using a pump will cost money (if you don't already have one). To produce a low pressure you can do what the old Steam Engineers used to do. Boil some water in a closed container. Seal the container with a thermometer inside it. Gradually let air in until the temperature drops to 60C and then re-seal. The water will still be boiling if the pressure is around 0.2 Atmospheres. Job done.
Best to do this with a large container so the 60C temperature will be maintained for a reasonable while. If you add heat (low power is probably enough) the water will stay boiling and condensing on the outside of the container. This is just the same process as boiling water in a normal pan where the ambient pressure is 1 Atmosphere. A bit of skill would be needed to maintain the 60C and you need to avoid the temperature exceeding anywhere near 100C or the pressure in the container will be positive and potentially dangerous.
The advantage of the "Urethane Degassing" containers is that the transparent lid rests in place on a silicon rubber seal. Positive pressure is therefore not possible.
You can implement a similar safe vacuum seal on another container. Make sure the cover is not screwed on. It must be held in place by the vacuum, so it will lift if subjected to any internal pressure.
That's interesting and shows that Engineers think about things when they design stuff!. But my concern was with someone who seems to fancy doing an experiment starting from scratch. I was stating the obvious but no harm in that when there's an accident waiting to happen. The idea in my head was to have a rubber bung with a short taper, in a hole with a similar taper. A 90 degree taper and a massive area sounds even better.
Likes Baluncore
This is pretty good. The only problem is that it's not easy to measure the temperature of the water as it boils in the syringe. As the demonstrator "claims" (of course, the claim may be true), the water actually cools down as it boils (owing to the latent heat that it loses as the steam extracts it from the water itself)! It would be cool ;-) if one could see that on a thermometer. So, I am enticed to try my own setup after I give the valve + syringe setup a try.
Standard trick is to use a heated water bath at 60C and keep the syringe under the water.
Likes OmCheeto
That would be an interesting maths problem: Find out the conditions in a syringe that you would need to generate an easily noticeable temperature change.
My guess is that the syringe would have to be very large, or the amount of water would have to be very small.
I'm also guessing that air in the apparatus would mess things up a bit.
I created a boiling display machine exactly as you have pictured. It worked fantastic. I used a vacuum desiccator, and a refrigeration grade vacuum pump.
The boiling temperature of the water is a function of the vacuum achieved by the pump. When I demonstrated it, the water would be at room temperature. When I started the pump, the water would start to boil. As there is no heat added to the vessel, and the liquid requires heat to boil, it would extract the heat from itself. As the water boils, its temperature drops. In my demonstration unit, it would take about 10 minutes of boiling before the temperature dropped to the freezing temperature, and Ice would form on the surface. it was and amazing demonstration for the principles of saturation temperature pressure relationships.
Likes sophiecentaur and KedarMhaswade
That's cool! Could you add a picture?
Just the part up to the water level, right? The rest in ambient air for condensation?
You can get big plastic syringes about an inch in diameter cheap at any pharmacy.
Is there a reason you want to boil water at 60 degrees or is than an arbitrary number less than 100 degrees?
Oh, yeah, just an arbitrary number less than 100. Any other number would also do. (Sorry for a late reply!)
To deal with the condensation, why not have two interconnected chambers - one with a heat source (water bath at 60C) and another 'condenser', kept cold. This could operate pretty much continuously - or until all the water had boiled off and moved to the condenser. The boiling point would be controlled by adjusting the pressure with an external warm syringe (you wouldn't want condensation inside the syringe). If you want a demonstration then this would work itself for a fairly long time (a tap could isolate the syringe once the right pressure is arrived at. This could use all school lab stuff.
FAQ: Cheapest equipment to boil water at 60℃
What is the cheapest way to boil water at 60℃?
The cheapest way to boil water at 60℃ is to use a stovetop or electric kettle. These are readily available and relatively inexpensive compared to other methods.
Can I use a microwave to boil water at 60℃?
No, a microwave is not an effective or safe way to boil water at 60℃. Microwaves heat water unevenly and can cause it to superheat, potentially leading to explosions.
Are there any DIY methods for boiling water at 60℃?
Yes, there are several DIY methods for boiling water at 60℃, such as using a solar cooker, homemade immersion heater, or a DIY sous vide setup. However, these may not be the most cost-effective options in the long run.
Is it possible to boil water at 60℃ without electricity?
Yes, it is possible to boil water at 60℃ without electricity. Some options include using a stovetop or campfire, solar cookers, or even a magnifying glass to concentrate sunlight.
Are there any safety concerns when boiling water at 60℃?
Boiling water at 60℃ is generally safe, as this temperature is hot enough to kill most harmful bacteria and pathogens. However, it is important to use caution and follow proper safety measures when handling hot water to avoid burns or scalding.
11K
12K
