Chemistry Chemical Equilibrium: find concentration from 2 solutions (ICE table)
The discussion focuses on understanding how to apply the ICE table to determine concentrations in a chemical equilibrium problem involving NO2 and N2O4. Participants express confusion about why values are plugged into (1-2x) instead of (1-2x)^2 in the equilibrium constant expression. It is clarified that while both approaches yield correct equations, using x=0.65 leads to a negative concentration for NO2, which is not physically viable. The correct method involves substituting values into the appropriate expressions to avoid unrealistic results. Ultimately, participants are encouraged to test their calculations to find the correct concentrations.
doridoridori
I've recently encountered this problem https://www.physicsforums.com/threads/need-major-help.117630/
In case the link doesn't open, here's the problem itself:
9. At a certain temperature, T, K for the reaction below is 7.5 liters/mole.
2NO2 <===> N2O4
If 2.0 moles of NO2 are placed in a 2.0-liter container and permitted to react at this temperature, what will be the concentration of N2O4 at equilibrium?
a) 0.39 moles/liter
b) 0.65 moles/liter
c) 0.82 moles/liter
d) 7.5 moles/liter
e) none of these
Super stuck on this. All of the deets are given in the question I linked. I'm still getting used to this forum so don't mind please if I accidentally mess something.
Also this is the equation itself:
7.5=x/(1-4x-4x^2)
30x^2-31x+7.5=0
x=0.39(approx.)
x=0.65(also approx.)
Hello! I've recently encountered this problem https://www.physicsforums.com/threads/need-major-help.117630/ and solved it and I'm stuck at choosing between 2 solutions. I don't understand why do we need to plug in 0.39 and 0.65 to (1-2x) and NOT to (1-2x)^2. I mean, we were given 2NO2, not just NO2. I see that in ICE table the result is [1-2x] but then why Keq=N2O4/(NO2)^2 and not just NO2?
Those are both correct solutions to your equation, but x=0.65 corresponds to a negative concentration of NO2, which is physically impossible.
Hello! Yes, that's essentially what I was asking. Sorry if I made it all unclear! So to know the right answer, we are plugging 0.65 and 0.39 into (1-2x). What I don't understand is why don't we plug it into K=x/(1-2x)^2 instead? I mean, we were given 2 moles of NO2, wouldn't it be reasonable then to calculate for 1-2x squared?
That is what you do plug into. Try those values and see what you get.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
