Chemical inhibitions of radioactive elements
The discussion centers on the feasibility of chemically inhibiting or blocking ionizing radiation from radioactive elements for the long-term storage of nuclear waste. It highlights that traditional methods, such as using lead for radiation shielding, rely on mechanical means rather than chemical processes. The distinction is made that chemical bonds and radiation mechanisms operate differently, with chemical interactions involving electron sharing, while nuclear radiation involves sub-atomic particles emitted from an atom's nucleus. Some research indicates that the electronic structure of materials can influence radioactivity, as seen in studies where the half-life of certain isotopes, like beryllium-7, is affected by their chemical environment. However, these effects are minimal and not directly applicable to the practical challenges of nuclear waste storage. Overall, while there are intriguing chemical interactions related to radiation, the consensus is that effective radiation blocking remains primarily a mechanical challenge rather than a chemical one.
Mayhem
Is it possible to chemically inhibit (block/absorb) ionizing radiation from radioactive elements, and is any research being done in this area to use it for long term storage of nuclear waste (in conjunction with other precautions, of course)?
Chemistry news on Phys.org
What does this mean? Why isn't blocking it with lead, for example, something that fits this description?
Likes russ_watters
If you could chemically inhibit, let's say, depleted uranium atomically such that the radiation is weakened, then transportation loads could be made lighter and accidental spills would be less catastrophic.
Lead attenuates (is that what you mean by "weaken"?) the radiation.
In case of (any dangerous level/type of) radiation, the chemical bonds and radiation are just not playing in the same league. Shielding/absorbing in general is done through mechanical means (radiation bashing around atoms, electrons, nuclei and losing energy while bouncing back and forth)(well, mostly true, up to a certain value of 'true'), since this has no upper limit on energy transfer.
Chemistry has.
The only say chemistry has in this matter is about holding the right obstacles in right place in a convenient way.
Likes BillTre
Blocking radiation chemically is sort of like blocking sound with a single sheet of paper, or a light beam with a single sheet of glass.
Chemical bonds involve the sharing of orbital Electrons between different atoms.
Nuclear Radiation is when a sub-atomic particular is emitted from the nucleus of an atom, and has nothing to do with the Electrons in orbit.
They are two completely different mechanisms.
Cheers,
Tom
Likes Astronuc
There are a few prominent instances where the electronic structure of a material will affect its radioactivity. Probably the most well-known is the case where a nucleus undergoes electron capture (inverse beta decay) as a decay mechanism. The half-life is dependent on the electron density at the nucleus, which is dependent on the chemical environment of the atom.
https://journals.aps.org/prl/abstract/10.1103/PhysRevLett.93.112501
In this PRL paper, beryllium-7 was observed to have a shorter half life (by several percent) when placed inside a fullerene. The higher electron density at the beryllium nucleus makes electron capture more likely, shortening the half life.
In principle, the half life for alpha decay should also change slightly when the electron density at the nucleus changes, as the Coulomb portion of the potential that the alpha has to tunnel through is altered. I have a vague memory of a paper from long ago saying this effect is very very small.
Technically, I guess Mossbauer spectroscopy falls into this camp too. The energy of a gamma photon emitted from an excited nucleus (usually Fe-57 or some cobalt nucleus) changes depending on the chemical environment the nucleus is in.
Likes Tom.G, Mayhem and Rive
None of that has any relevance to the OP's application of storing nuclear waste.
