Chemistry Help: Plant Nutrients and Environmental Impact
  • Thread starter Thread starter brandong
    Chemistry Urgent
Insufficient potassium, nitrogen, or phosphorus in plants can lead to poor growth, reduced photosynthesis, and impaired energy transfer. The use of NPK fertilizers can significantly harm the environment by leaching into water bodies, causing harmful algal blooms that deplete oxygen and threaten aquatic life. Alternatives such as compost and manure are more environmentally friendly, as they provide nutrients with lower leaching potential. Nutrients in the soil reach plants primarily through diffusion in the root system. Understanding these dynamics is crucial for sustainable agricultural practices.
brandong
3. Homework Statement
What would happen if a plant could not obtain enough of the following nutrients from the soil?
a) Potassium
b) Nitrogen
c) Phosphorus
5. How can using fertilizers to improve crop yield impact on the evironment
6. Carry out some research to identify alternatives to adding NPK fertilizer to the soil - highlighting why they are better for the environment?
8. How do minerals in the soil get to where they are needed in the plant?
n/a
Out of 10 questions, these are the ones I can't do. Please help
Sorry it's Biology.
It's pretty simple if you think about it
a) Potassium
b) Nitrogen
c) Phosphorus
Think about it, what are these elements used for in plants.
Potassium: Mainly involved in enzymes, also involved in the opening and closing of stomata.
Nitrogen: used in protein synthesis, also a important component in chlorophyll, holds the mg metal in place.
Phosphorus: Used in ATP, i.e. the product of respiration, Also an important part of DNA.
Now what would happen if plants could do these processes very efficently?
NPK fertilizers rely on soluble nitriates or nitrites, this means that they can be easily leeched away. These nutrients often get leeched into local rivers, this causes algae to grow far too fast. Where they decompose, all the oxygen is used out of the water, thus causing fish and such to die.
Plant matter, cow dung. They generally involve less soluble nitogen sources and so are less porone to leeching
They diffuse through the roots, how else.
how that helps:smile:
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
