Chemistry Problem- Burning Magnesium
The primary product of burning magnesium is magnesium oxide (MgO), not Mg2O3, as clarified by participants in the discussion. The mole ratio of magnesium to oxygen in the reaction is 2:1, leading to the formation of MgO. Concerns were raised about measurement accuracy due to the quality of lab equipment, which could affect results. Additionally, the purpose of adding distilled water and evaporating it was questioned, alongside the potential for nitrogen contamination during the reaction. The discussion highlights the importance of precise measurements and understanding chemical reactions in laboratory settings.
rasperas
Short Question- What is the product resulted from burning magnesium?
More Detail- For a chemistry lab I had to react magnesium oxygen- and thereby find out the empirical formula. Below is the lab procedure and my work.
Procedure-
1) Heat a clean dry crucible to redness. (to prevent extraneous r/x's)
2) Allow crucible to cool and mass and record.
3) Cut a piece of Mg ribbon about 5 cm. long.
4) Measure the length of Mg and record (+_ .0001 m) mass 1.00m MG = 1.2819
5) Break the Mg ribbon into small pieces into the bottom of the crucible.
6) Set crucible on ring stand/ clay triangle.
7) Heat 7-10 minutes.
8) Check for and unreacted Mg.
9) Allow crucible contents to cool.
10) Add just enough distilled water to cover the contents in the crucible.
11) Gently heat the crucible again to dry the product.
Data
a. Mass crucible 19.29
b. length Mg .0461 M (46.1 mm)
c. mass crucible and product 19.41 g.
Analysis
Mass Mg 1.2819 x .0491 = .0591
Mass O 19.41-19.29-.0591
Mole Mg .0591 g / 24.305 = .00243 mol Mg
Mole O .06 g / 15.999 = .004 mol O
Mol Ratio .004/.00243 = 1.6 mol 0 per 1 mol Mg x 2 (b/c empirical formulas contain integers only)
Allowing for room of error I get Mg2O3. However here's the rub. Mg= charge 2+
O = charge 2-. 2 x 2 = Total charge of 4+ on Mg. 2 x 3 = total charge of 6- on O. Unablanced.
Is this answer (Mg2O3) correct or is it wrong -(too many innacurate measurments in the data).?
Out of curiosity- What is the purpose of adding distilled water and then evaporating it? The cover to the crucible was on most of the lab- but never-the-less, is this sufficient to prevent nitrogen from skewing the results by reacting with Mg?
Thanks,
Rod Aspera
Magnesium oxyde.MgO
Procedure-
Data
b. length Mg .0461 m (46.1 mm)
Analysis
Thanks,
Rod Aspera
Check your numbers,again.Give units in SI:m,Kg,s.What is the linear density of Mg??Give the figure in Kgm^{-1}.
There's no such thing as
Mg_{2}O_{3}
The mole ratio should be
2moles of Mg+1mole 0_{2}=2moles MgO.
One mole of oxigen has 32g=0.032Kg,not 16g=0.016Kg
Daniel.
For personal simplicity, I was just expressing oxygen as non-diatomic; everything in the problem was adjusted to allow this.
Thankyou for the help.
After thinking about the problem, I realized it is an issue of accuracy. The rulers provided by school are standard "walmart" rulers. The scales also aren't scientific quality.
For "personal simplicity" means entering conflict with science.One mole of Oxigen has N_{A} molecules and that's exactly 32g,not 16g.Oxigen is diatomic,and in chemical reactions it will always enter as a diatomic molecule;only under exceptional conditions it appears monoatomic,e.g.the redox reactions involving H_{2}SO_{4},H_{2}O_{2},HNO_{3},H_{2}SO_{5} and so on.but in this case,it is a product of reaction,not a reactant.
Daniel.
Daniel.
My question is alwo related to Mg burning. We did the experiment at school & after MgO was produced, we massed it. It turned out that the amount of oxygen in MgO was negative--MgO weighed less than the Mg I started out with.
I'm assuming it's because smoke was given off. But why was smoke produced & what exactly is in that smoke?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
