Chemistry: would someone verify my work, please?
  • Thread starter Thread starter bjoyful
    Chemistry Work
The discussion revolves around a chemistry homework problem involving the calculation of nitrogen percentage and mass produced from burning coal represented by the formula C135H96O9NS. The calculations show that the percent of nitrogen by mass in the coal is approximately 0.734%. When three tons of coal are burned, it is determined that 42.8 kg of NO would be produced, assuming complete conversion of nitrogen in the coal. Clarifications are provided regarding whether the final figure represents nitrogen alone or the total mass of NO, emphasizing the need to express results in appropriate units. The calculations are confirmed as correct, and the importance of understanding the composition of NO is highlighted.
bjoyful
Assume that coal can be represented by the formula C135H96O9NS. A. What is the percent of nitrogen by mass in this coal? B. If three tons of coal were burned completely, what mass of nitrogen in NO would be produced? (Assume that all of the nitrogen in the coal is converted to NO in the burning process.) Be sure to show all your calculation work in each case.
A.135x12.01=1621.35 (carbon) + 96x1.008=96.76 (hydrogen) + 9x16.00=144 (oxygen) + 1x14.01=14.01 (nitrogen) + 1x32.07=32.07 (sulfur) = 1908.19. 14.01x100/1908.19= 0.734%.
B.First, to find the moles of coal in 6000lbs of coal, I converted the pounds to grams and divided it by the mole weight (6000 x 453.6 / 1908.19 = 1426.27). Since one mole of coal provides one mole of NO, there are 1426 moles of coal and 1426 moles of Nitrogen. NO has a molar mass of 30g/mol, so 30g/mol x 1426 moles = 42.8kg of NO. Therefore, the mass of nitrogen in NO that would be produced when three tons of coal is burned completely is 42kg. (Am I including both nitrogen and oxygen in this figure? I'm only suppose to be looking for nitrogen??)
I want to make sure I have done this right. If not, please point me in the right direction:)
So you've got 42.8 kg of NO. They want to know how much of this is nitrogen.
Is 42.8kg the correct number of NO? Is there a formula to use to find how much of this is N?
I've checked your work and it seems that that is the correct answer.
Think about 1 mol of NO. What percent of this (in terms of mass) is nitrogen?
The question asks you for the mass of NO, not N. Relax, you have it. You might want to express it in either tons or pounds for completeness.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
