Chernoff Bounds using importance sampling identity
  • Thread starter Thread starter WMDhamnekar
The discussion focuses on using the importance sampling identity to derive Chernoff bounds for a binomial random variable. It outlines the process of bounding the probability that the random variable deviates from its mean by more than a specified amount. By defining the binomial variable as a sum of independent Bernoulli trials and applying the importance sampling technique, the probability is expressed in terms of expectations under a different measure. The resulting Chernoff bound is formulated, allowing for the selection of a suitable parameter to achieve a tight bound on tail probabilities. The solution is presented as correct, inviting further questions for clarification.
WMDhamnekar
MHB
How to use importance sampling identity to obtain the Chernoff bounds as given below?
Let X have moment generating function ##\phi(t)= E[e^{tX}]##. Then, for any c > 0 ,
##P[X\geq c ]\leq e^{-tc} \phi(t), \text{if t > 0}##
##P[X \leq c]\leq e^{-tc}\phi(t), \text{if t<0} ##
Solution:
Here's an example of using the importance sampling identity to obtain Chernoff bounds for a binomial random variable.
Suppose we have a binomial random variable ##X \sim \text{Bin}(n,p)##, where n is the number of trials and p is the probability of success on each trial. We want to bound the probability that X deviates from its mean by more than a certain amount, i.e., we want to bound ##P(X \geq (1+\delta)np)## for some ##\delta > 0##.
Let ##X = \sum_{i=1}^n X_i##, where the ##X_i## are independent Bernoulli random variables with parameter p. Let ##Q_i## be a Bernoulli distribution with parameter q, and let ##Q = Q_1 \times \cdots \times Q_n##.
Then, by the importance sampling identity, we have ##P(X \geq (1+\delta)np) = E_Q\left[\prod_{i=1}^n \frac{dP_i}{dQ_i}I_{X \geq (1+\delta)np}\right]##
Now, let ##\phi_i(t) = E[e^{tX_i}] = 1 + p(e^t - 1)## and ##\psi_i(t) = E_Q[e^{tX_i}] = 1 + q(e^t - 1)##.
By choosing ##Q_i## such that ##\frac{dP_i}{dQ_i} = e^{tX_i - \log \phi_i(t)}##, we obtain ##P(X \geq (1+\delta)np) = E_Q\left[e^{tX - n\log \phi(t)}I_{X \geq (1+\delta)np}\right]##
Applying Markov's inequality, we get ##P(X \geq (1+\delta)np) \leq e^{-t(1+\delta)np}E_Q\left[e^{tX - n\log \phi(t)}\right] = e^{-t(1+\delta)np}\prod_{i=1}^n\psi_i(t)e^{-\log \phi_i(t)} = e^{-t(1+\delta)np}\left(\frac{1+q(e^t-1)}{1+p(e^t-1)}\right)^n##
This is the Chernoff bound for a binomial random variable. By choosing an appropriate value of t, we can obtain a tight bound on the tail probability.
In my opinion, this solution seems to look correct. Do you have any doubts? Let me know, so that I shall clear them.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
