Choosing a Flexible hose for outlet air pressure vessel
When selecting a flexible hose for outlet air pressure vessels operating at 11 bar, it is crucial to consider the maximum working pressure, which should exceed the system's requirements. The term "inst air" refers to instrument air, a type of compressed air that is dried and oil-free, commonly used in industrial applications. Standard rubber air hoses available in hardware stores typically have a working pressure rating of 300 PSI (20 bar). In some industrial settings, the design pressure for piping may be two to three times the operating pressure, with pneumatic signals often running at much lower pressures. Compliance with local laws and safety regulations regarding maximum pressure is essential, especially in specific environments like assembly lines.
guideonl
TL;DR Summary
Flexable hose choosing for outlet air pressure vessel
Hi everyone,
What should be the considerations to choose the proper hose (max working press) installed at outlet air pressure vessels (11 bar) for industrial purposes? Please remark source\link.
Also, I've found a table which lists the max sys operating press for 4 different fluids (fuel, oil, hyd/pneu, inst air). What is the abrreviation inst mean?
Thank you
Ask/look for standard air hose. The standard rubber air hose in a local hardware store is specified for 300 PSI (20 bar) working pressure.
Inst air is probably instrument air. Instrument air is compressed air that has been dried (moisture removed) and does not have oil added.
Likes russ_watters, dlgoff and berkeman
Right, instrument air is used in industrial applications (eg, chemical plants, power plants, etc). The IA can be used to operate valves, and various control devices.
guideonl said:
... I've found a table which lists the max sys operating press for 4 different fluids (fuel, oil, hyd/pneu, inst air). What is the abrreviation inst mean?
This must be some kind of generic table listing "typical" values. The plants I worked in had instrument air at around 100 psig (6.9 barg). I do not recall the system design pressure (for the piping, etc.) probably twice or three times that. Many of the air-operated instruments run at much lower pressure. Pneumatic signals are typically 3-15 psi for 4 - 20 ma signals.
Thank you jrmichler
If this is for general use in areas like assembly lines for electronic equipment, pay attention to the local laws & safety regulations.
Here in California (and maybe Federal) there is a maximum pressure you must not exceed. I don't recall the exact number but believe it is around 30-50PSI (2-3bar).
We would put a pressure regulator at the head of each assembly line, but put one connector for "Supervisor Use Only" at the head end before the regulator to get the 100PSI (7bar) line pressure. That one got a lot of use!
Of course if you are powering tools or equipment you use whatever is needed.
Cheers,
Tom
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
14K
