Choosing an efficient compressor
  • Thread starter OlegZin
  • Tags
    Compressor
In summary, the engineer suggested a screw compressor because it is more efficient than a reciprocating compressor.
OlegZin
Hello everyone. I'm working those days on my graduation project, and I need a little assistance. I have to choose a compressor that would be driven by diesel engine. The compressor should supply about 1.7 kg air and compress it to 2 atmospheres.
It seems that centrifugal compressor or axial may fit, but I got a constraint that its efficiency will be about 90% or more which is pretty high, and these compressors typical efficiency may reach 80-85%. Compressors that do have such efficiencies are reciprocating compressors, but they are not able to supply the appropriate air flow.
Would be glad to hear any suggestions. Tried to find relevant threads in the forum but didn't find one that may help, if you know any, let me know
Thanks in advance
That's too general...already tried this...
Does the diesel have to be directly linked to the compressor? Can you use a diesel-electric setup? Usually compressor flow rates are measured in volumetric flow rates at several given pressures. Do you mean mass flow rate by the 1.7 kg? And why wouldn't reciprocating work? With enough RPMs and displacement, you should be able to get the flow rate you want at the compression you need. Do you mean you can't find any on the market like this?
The diesel have to be linked directly. The flow rate is about 1300 liters per seconds. It's a big flow rate, compressors that I've found on the net, supplying such a volume per minut and not second. one of the most important factors for me is high efficiency. in order to supple this flow the compressor must run on a high RPMs, and this may drop the efficiency because of losses doesn't it? What may be the solution for this?
What is this for?
A compressor capable of over 2000CFM will probably be over $100k, have an engine with hundreds of HP and come on a multi axle trailer.
How long do you need to supply the required flow rate for? If it's short term, a smaller compressor with a reasonable sized receiver (and a high flow regulator) might work.
Interesting idea regarding the small compressor, but anyways, it suppose to work continiously without any time limits. Regarding the price, it doesn't really matter, I'm not going to buy it, it just have to efficient.
I don't think this will be an off the shelf item, or at least will be POA and presumably you'll need a written quote for your design report.
so I think your best bet is to talk to sales engineers at compressor suppliers, IME if you are well prepared and know what you need (ie you need to use industry standard units for a start...) they are more than happy to help even when they know it won't result in a sale, you can sweeten the deal by offering an acknowledgment in your design report or poster. They will want to know what it's for (like we do here :wink: ), they may even have a better solution.
Billy, thanks for advice. Today I've talked with engineering department in a compressor supplier company. Term of "isentropic efficiency" sound to him like a curse. He didn't really know what is it efficiency, may be he used to work with catalogues and efficiency never mentioned there. He said that since I have such a volume to compress, in real life situation, he would suggest a screw compressor.
In general, purpose of my project is to develop system that would increase efficiency of a diesel engine by use of waste energies. The idea is that engine will drive the compressor, compressed air will be heated by cooling the engine and exhaust gases. Output power will come from kind of turbine\expander and not the engine it self, hopefully to increase total efficiency. This reminds Braiton cycle. In order to achieve this I need that other components would be as efficient as possible.
Related to Choosing an efficient compressor
1. What factors should be considered when choosing an efficient compressor?
When choosing an efficient compressor, it is important to consider the size and type of compressor needed for your specific application. Other important factors include the compressor's horsepower, pressure and flow rate, as well as its energy efficiency and maintenance requirements.
2. How can I determine the energy efficiency of a compressor?
The energy efficiency of a compressor can be determined by looking at its specific power rating, which is the amount of energy consumed per unit of compressed air produced. A lower specific power rating indicates a more energy-efficient compressor.
3. What is the recommended maintenance schedule for an efficient compressor?
The recommended maintenance schedule for an efficient compressor will vary depending on the specific model and manufacturer. However, it is generally recommended to have the compressor serviced at least once a year, and to regularly check and replace the air filter, oil filter, and belts as needed.
4. Are there any additional features I should look for in an efficient compressor?
Yes, there are several additional features that can enhance the efficiency of a compressor. Look for compressors with variable speed drives, which can adjust the motor speed based on demand, as well as models with high-efficiency motors and advanced control systems.
5. How can I ensure the longevity of an efficient compressor?
The best way to ensure the longevity of an efficient compressor is to follow the manufacturer's recommended maintenance schedule and to regularly monitor and address any potential issues. It is also important to properly size the compressor for your specific needs, as an undersized or oversized compressor can lead to premature wear and tear.
  • DIY Projects
9K
  • Electromagnetism
  • Other Physics Topics
