Circle a equation in a straight line
In summary, the conversation is discussing the equations for three straight lines and two parabolas, and the concept of "circling" an equation in a straight line is unclear. The equations for straight lines do not contain exponents, while the equations for parabolas do.
Abdullah Qureshi
how to circle a equation in a straight line
y= 2x-1
y = x^2+ 2
x –y = 1
x = y + 5
y = – x^2 + 5
pls help me
Mathematics news on Phys.org
You’ve posted the equations for three lines and two parabolas.
I have no idea what you are asking with regard to a circle.
Please translate the original problem to English and post it.
https://www.physicsforums.com/attachments/11038
Can you without the graph
Do what?
Are you asking which of the five equations are lines?
I don't understand what "to circle an equation in a straight line".
means.
y= 2x-1
This is the equation of a straight line.
y = x^2+ 2
This is the equation of a parabola.
x –y = 1
x = y + 5
y = – x^2 + 5
pls help me
There are NO circles.
It possibly means to encircle the equations forming straight lines.
skeeter said:
Do what?
Without making a graph. It can be use as simple way like trigonometry
Straight-line equations, or "linear" equations, graph as straight lines, and have simple variable expressions with no exponents on them. If you see an equation with only x and y, then you're dealing with a straight-line equation. As opposed to, say x² or √x .
The second and the last equations posted above have exponents, so they are not forming straight lines. The rest of them are. You can encircle the rest!
Likes Greg Bernhardt
Related to Circle a equation in a straight line
1. What is a circle equation in a straight line?
A circle equation in a straight line is a mathematical representation of a circle on a Cartesian coordinate system. It is in the form of (x-h)^2 + (y-k)^2 = r^2, where (h,k) represents the center of the circle and r represents the radius.
2. How do you graph a circle equation in a straight line?
To graph a circle equation in a straight line, first plot the center point (h,k) on the coordinate plane. Then, use the radius r to plot points on the circle. Connect the points to form a smooth curve, which will be the circle.
3. Can a circle equation in a straight line have a negative radius?
No, a circle equation in a straight line cannot have a negative radius. The radius represents the distance from the center of the circle to any point on the circle, so it must be a positive value.
4. How is a circle equation in a straight line different from a regular circle equation?
A circle equation in a straight line is different from a regular circle equation because it is in the form of (x-h)^2 + (y-k)^2 = r^2, while a regular circle equation is in the form of x^2 + y^2 = r^2. The difference is that a circle equation in a straight line is centered at a point (h,k) instead of the origin (0,0).
5. What is the significance of a circle equation in a straight line in real life?
A circle equation in a straight line has many applications in real life, such as in engineering, architecture, and physics. It is used to represent circular objects or motions, such as wheels, gears, orbits, and circular paths. It also has practical uses in calculating distances, areas, and volumes.
  • General Math
  • General Math
  • General Math
  • General Math
