Circular motion question - finding rpm
A 0.60 kg sphere rotates around a vertical shaft, with the upper string tension measured at 18 N. The discussion focuses on calculating the tension in the lower string and the rotation rate in revolutions per minute (rpm). The centripetal force was calculated to be approximately 20.92 N, leading to a velocity of 3.74 m/s. This velocity was then used to determine an angular velocity of 9.35 radians/sec, which converts to about 89.2 rpm. The participants confirmed the calculations and clarified the radius used in their computations, resolving any discrepancies.
jgray
A 0.60 kg sphere rotates around a vertical shaft supported by two strings, as shown. If the tension in the upper string is 18 N. Calculate
the tension in the lower string?
the rotation rate (in rev/min) of the system?
v=2(pi)r/T
Fr= mv^2/r
ω = v/R
I believe I have the first part correct, my question is really about the second part. For the second part of the question: I calculated the x components of each tension force to find the centripetal force = 20.96N. I then found the velocity by rearranging the equation: Fr = mv^2/r to get 3.74m/s. I used the equation ω = v/R to get 9.35 rads/sec and converted it to 89.3 rpm by multiplying 9.35 by 60s and dividing it by 2(pi). Am I on the right track?? Just seems like a small answer…
The upper string has to supply force for the mass to rotate and to stay afloat.
[strike]Don't follow the 3.74 m/s. Did you divide by 6 or (0.6 x 9.81) instead of by 0.6 kg ?[/strike]
(Edit: Jgray is fully correct)
I don't see any workings of the first part.
@aziz: I think the poster is happy with the result of the first part (I support him/her in that) and now asks for help in the second part.
[strike]If I fill in v = 3.74m/s in mv^2/r I do not get the 21 N...[/strike]
Hmm, maybe I do have an error in my first part then. I found the centripetal force:
T1x+T2x =
sin θ(T1) + sin θ(T2)=
sin53(18N) + sin53(8.2N) --8.2 N is the answer i found for the second tension force for part 1--
14.37+6.55
20.92N
For the velocity:
v^2= Fr(r)/m
(20.92N)(0.4m)/0.6kg=
square root of 13.95=
3.74m/s
Fully correct, it was me that used r=4 (from the 3,4,5 triangle) instead of the 0.4 in the exercise. Sorry.
So the 3.74 is fine too. And the 9.35 and the 89.2.
Thanks for the help! :)
:redface:
