Circular motion x, y acceleration
The discussion centers on calculating the x and y components of a car's acceleration while traveling around a circular track. Users emphasize the importance of including units in calculations and understanding the derivation of values used in the equations. There is a focus on ensuring that the signs of the acceleration components are correct, as well as the direction of the acceleration vector in circular motion. The conversation highlights the need for clarity in problem-solving to avoid confusion in future calculations. Understanding the underlying concepts is crucial for confidence in the answers provided.
aruji73
Can you tell me if my answers and sign are correct ?
A car is traveling around a horizontal circular track with radius r = 250.0 m at a constant speed v = 18.0 m/s as shown. The angle θA = 19.0° above the x axis, and the angle θB = 60.0° below the x axis.
What is the x component of the car’s acceleration when it is at point B = 0.527
What is the y component of the car’s acceleration when it is at point B = 1.1859
As the car passes point B, the y component of its acceleration is-increasing
Welcome to PF;
Well you left off the units ... that's marks lost right there.
How did you come by those numbers?
Note: it is possible to get the right answer despite misunderstanding the problem... but if you understand the problem, you'll probably also be confident with your answer. s there some special reason you are concerned about your answers?
I am concerned if my signs are right
i.e. at any point in the circle, describe in words the direction of the car's acceleration.
What is the x component of the car’s acceleration when it is at point B = 1.296*cos60
What is the y component of the car’s acceleration when it is at point B = 1.296*sin60
are both the magnitudes going to have a positive value ?
Which direction does the acceleration vector point in circular motion at constant speed?
Draw the acceleration vector arrow on your diagram.
When you have done that, you will know if your signs are correct.
You have still not provided units.
You have still not said how you got those numbers: where did 1.296 come from?
I'm not doing this just to be pedantic or make your life difficult! What I am trying to do is direct your attention to where the answer to your question lies. The idea is that, next time, you won't have to ask.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
