I Circular Orbit in Schwarzschild: Orbital Period
epovo
TL;DR Summary
I followed Schutz derivation and I don't get his result
Schutz finds that the orbital period for a circular orbit in Schwarzschild is
$$ P = 2 \pi \sqrt {\frac { r^3} {M} }$$
He gets this from
$$ \frac {dt} {d\phi} = \frac {dt / d\tau} {d\phi/d\tau} $$
Where previously he had ## \frac {d\phi}{d\tau} = \tilde L / r^2## and ## \frac {dt}{d\tau} = \frac {\tilde E} { 1 - 2M/r}## and where
## \tilde L^2= \frac {Mr } { 1-3M/r}## and ##\tilde E = \frac {(1- 2M/r)^2} {1-3M/r} ##
After doing the algebra I don't get that expression for the period (I get a much more complicated expression).
I punched in some numbers for M and r in a spreadsheet and the period given by the expression above does not match the calculations I have done. It does not even seem to be a very good approximation. Help, please!
It's in ch 11 section 1 (page 280 in my edition) under Perihelion Shift
Your expression for ##\tilde{E}## is wrong - it's the correct expression for ##\tilde{E}^2##. Schutz has it correct in equation 11.21 on p287 in my edition, and I think his result for ##P## follows.
You may have made a transcription error, or there may be a typo in your edition. Either is possible - I've commented before that I think Schutz needed a better editor.
Likes berkeman, epovo and vanhees71
Definitely a typo. Thank you!
Likes Ibix and berkeman
epovo said:
Definitely a typo.
I have the second edition, so I hope you have the first edition... This particular text does seem to have more than usual stuff like this, so I would say that when you can't make sense of Schutz, "my textbook is wrong" (or at least confusingly written) should be a bit higher up your probability list than normal.
  • Haha
Likes vanhees71 and PeterDonis
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
Thread 'Relativity of simultaneity in actuality'
I’m attaching two figures from the book, Basic concepts in relativity and QT, by Resnick and Halliday. They are describing the relativity of simultaneity from a theoretical pov, which I understand. Basically, the lightning strikes at AA’ and BB’ can be deemed simultaneous either in frame S, in which case they will not be simultaneous in frame S’, and vice versa. Only in one of the frames are the two events simultaneous, but not in both, and this claim of simultaneity can be done by either of...
