Circumcentre of an equilateral triangle
The distance from a corner of an equilateral triangle to its circumcenter can be calculated as a/sqrt3. A perpendicular dropped from the circumcenter to a side forms a 30-60-90 triangle, where the hypotenuse represents the circumradius. The previously calculated distance from the vertex to the opposite side, a*sqrt(3)/2, can be used in conjunction with the Pythagorean theorem to find the circumradius without relying on trigonometric functions. This approach simplifies the calculation while confirming the circumradius formula. Understanding these relationships is key to solving problems related to the circumcenter of equilateral triangles.
Chronos000
1. Homework Statement [
what is the distance from one corner of an equilateral triangle of sides a to the circumcentre?
I can figure out the length from one corner to the opposite side to be sqrt3*a/2 but that's about it. I just can't see how to do this.
thanks
Drop a perpendicular from the circumcenter to a side. That gives you a 30-60-90 triangle whose hypotenuse is the radius you are looking for.
thanks, the answer is a/sqrt3, I thought there was some way to do this without cos or sin but perhaps not
You could just use the pythagorean theorem if you really want to. If you call the circumcircle radius r, then the a*sqrt(3)/2 distance you computed minus r is the shorter leg of your 30-60-90 triangle. Now use the pythagorean theorem on it to solve for r. You don't really NEED the trig.
  • · Replies 16 ·
  • · Replies 16 ·
10K
