Clarification about Aircraft Over-Wing Fog Formation (Adiabatic)
  • I
  • Thread starter RobbyQ
  • Tags
    Aircraft
In summary, when airliners land or take off on humid days, a fog or cloud may develop on the upper wing due to the lower pressure on the wing's surface causing rapid adiabatic expansion and resulting in a drop in temperature near the dew point. This can also be likened to the fog that occurs when opening a can of fizzy drink. However, the fog may not always occur due to changes in atmospheric conditions and the magnitude of the low pressure can vary. The fog disappears when the spoilers are deployed and the upper wing pressure returns to the airfield pressure, indicating the shedding of lift. This can also be seen through the compression of the landing gear suspension system. The fogging effect is also affected by air temperature and humidity
RobbyQ
25
You may have noticed when airliners land or take off on humid days a fog or cloud develops on the upper wing. My understanding is that the upper wing has a lower pressure (Bernoulli's) than the atmospheric pressure (QNH) at the airfield. When the air molecules hit the upper wing there is a rapid adiabatic expansion due to the lower pressure and work is done, resulting in a drop in temperature within 2.5C of the dew point. Condensation onto dust particles occurs and the fogging is observed. I also liken this to that small cloud you get when you crack open a can of fizzy drink. Would this be correct?
Here is a link of the fogging effect:
Science news on Phys.org
That is basically correct, but dew point changes according to atmospheric conditions, reason for which the foggy cloud on top of wings not always happens.
Also, the magnitude of the low pressure also varies according to wing velocity and angle of attack.
Likes RobbyQ
Good feedback. Thanks.
Also, did you notice on the touch down in the video where the spoilers were deployed, lift dump occurs and the fogging disappears as the upper wing is back to the airfield pressure.
Likes Lnewqban
Perhaps the best indicator is that at about 0:53 in the video. As the jet touches down and load shifts from the wings to the landing gear, that wing fog disappears proportionately to the landing gear compression - clearly indicating that it is the direct product of the lift.
Likes Lnewqban and RobbyQ
I think that's lift dump as spoilers deployed and upper wing pressure is back to standard. Also killing the lift, as you implied, means all the weight is back on the wheels and improves braking efficiency.
At 0:52, the wing fog is gone and the spoilers are not deployed. The first sign of the spoilers is over a second later at 0:53. Because spoilers increase the stall speed, it is normal practice to land before fully deploying the spoilers as brakes.
I think the best indication of the shedding of the lift is the compression of the landing gear suspension system.
I have piloted aircraft with air brakes (not spoilers). I love them. They give super precise control of your descent angle.
Likes Lnewqban
.Scott said:
At 0:52, the wing fog is gone and the spoilers are not deployed. The first sign of the spoilers is over a second later at 0:53. Because spoilers increase the stall speed, it is normal practice to land before fully deploying the spoilers.
The spoilers are armed and deploy when the rea wheels touch the runway. I don't think we can argue about what happens within 1 second here. Also it's just coming out of the flare so angle of attack is decreasing. Spoilers are 2 fold: 1. During the descent procedure they act as air brakes (if needed) 2. On touch down they kill the lift and get that 1G back onto the wheels for efficient braking.
Likes Lnewqban
For the airplane flying a constant bank (timelapse 1:41 through 2:07), note that the above-wing pressure (and AOA) should remain more or less constant but fogging appears and disappears according to the air temperature and humidity in different zones.
Indeed.
You can also see how the bending (smiling) along the wingspan disappears.
The weight is transferred from the hanging wings onto the rolling gear.
Likes RobbyQ
Indeed. Very noticeable. There's a lot going on here. Time for some Navier-Stokes :smile:
Likes Lnewqban
Related to Clarification about Aircraft Over-Wing Fog Formation (Adiabatic)
What causes fog to form over an aircraft's wings during flight?
Fog over an aircraft's wings is caused by the adiabatic cooling of air. As air flows over the wing, it speeds up and its pressure decreases. This reduction in pressure leads to a drop in temperature, sometimes reaching the dew point, causing water vapor to condense into tiny droplets, forming fog.
Is over-wing fog formation dangerous for the aircraft?
Over-wing fog formation is generally not dangerous. It is a visual phenomenon indicating local changes in air pressure and temperature but does not affect the aircraft's performance, structural integrity, or safety.
Does over-wing fog occur at specific altitudes or speeds?
Over-wing fog can occur at various altitudes and speeds, but it is more commonly observed during takeoff and landing when the aircraft is moving through moist air and experiencing significant changes in speed and pressure.
How does the adiabatic process contribute to fog formation over the wings?
The adiabatic process involves changes in temperature and pressure without the exchange of heat with the environment. As air flows over the wing, it expands and cools adiabatically. If the temperature drops below the dew point, the moisture in the air condenses, forming fog.
Can over-wing fog be used to infer any specific aerodynamic properties of the aircraft?
Yes, over-wing fog can provide visual clues about the airflow and pressure distribution over the wing. It can indicate regions of low pressure and high velocity, helping in understanding the aerodynamic behavior of the aircraft, particularly during critical phases of flight like takeoff and landing.
  • Other Physics Topics
