Clarification on force on frictional surface constant speed
In summary, the correct understanding is that the applied forces are acting on the objects to maintain their constant speed, even though they may be canceled out by other forces. The object is still subject to forces, even if the net force on it is 0.
meloettakawaii
for the following 2 examples from:
http://www.physicsclassroom.com/class/energy/Lesson-1/Calculating-the-Amount-of-Work-Done-by-Forces
A 10-N force is applied to push a block across a frictional surface at constant speed for a displacement of 5.0 m to the right.
Would it be more accurate to say that a 10-N force is applied to 'Maintain' (not to push or pull) a block across a frictional surface at constant speed for a displacement of 5.0m to the right?
because the 10-N force is acting upon the frictional force canceling it out in order for the block to continue moving at its original velocity. the 10-N force isn't acting on the block to push it when it is canceled out by friction. the block is in equilibrium with constant velocity.
also
An approximately 2-kg object is pulled upward at constant speed by a 20-N force for a vertical displacement of 5 m.
Would it be more accurate to say that an approximately 2-kg object is 'moving' upward at a constant speed 'maintained' by a 20-N force for a vertical displacement of 5 m?
because again, the tension force is acting not on the object but on the force of gravity. (any excess would be acting on the object). if a force is canceled out, it can't act on the object!
thanks.
Likes Pierce610
also
thanks.
Your thinking is not correct. Forces act on objects, not on other forces. In your second example, the 20 N applied force acts upward on the object, and the 20 N weight force (gravity force) acts downward on the object. Together, the net force acting on the object is 0, so the object, once set in motion with a nudge, moves at constant speed , per Newton 1. Or in your first example, both the applied 10 N force and the opposite 10 N friction force act on the object. If you were the 'object', you would certainly feel an internal force acting on you, even though the net external force acting on you is 0.
Related to Clarification on force on frictional surface constant speed
1. What is the force on a frictional surface at constant speed?
The force on a frictional surface at constant speed is called the kinetic frictional force. It is the force required to keep an object moving at a constant speed on a surface with friction.
2. How is the force of friction related to the weight of an object?
The force of friction is directly proportional to the weight of an object. This means that as the weight of an object increases, the force of friction also increases.
3. Does the force of friction change with speed?
No, the force of friction does not change with speed as long as the object is moving at a constant speed. This is because the force of friction is independent of the object's velocity.
4. How does the force of friction affect the motion of an object?
The force of friction acts in the opposite direction of motion, slowing down or stopping the object. It can also cause the object to move in a different direction if the surface is not flat.
5. Can the force of friction be completely eliminated?
No, it is impossible to completely eliminate the force of friction. However, it can be reduced by using lubricants or by using materials with lower coefficients of friction.
  • Mechanics
