- 42,708
- 10,459
The safe way to approach any idealised problem, such as inelastic strings, is to start with at least an approximation of the general case then take the limit.
For simplicity, I'll just analyse the case where the blocks are massless, and treat them as a continuum. So we just have a point loaded beam, except that its resistance to shear comes only from friction.
Let the weight W be placed at distance S, at least half way along a beam of length L and depth H. Say the horizontal force F through the beam was negligible before W was applied, but the ends of the beam are kept fixed.
The weight creates shear forces and torques in the beam. The torques are balanced by the effective line of action of the horizontal force changing along the beam. This comes about because each vertical slice through the beam of thickness dx (a block, in the original problem) gets rotated a fraction by the torque from the shear forces.
If we assume the blocks are sufficiently rigid and sufficiently tall that they cannot rotate completely out of position then this line of action will be at the base of the beam at each end and at the top of the beam at S.
This leads to ##FH=W\frac{(L-S)S}L##.
If nothing slips then ##\mu F## must exceed the maximum shear force, i.e. ##W\frac SL## (since I chose S>=L-S).
W disappears, leaving ##\mu\geq \frac{H}{L-S}##.
This is minimised at S=L/2.
Note that the compression force depends upon the placement of the weight, so taking that force to be a given could lead to the wrong answer.
Reintroducing a mass for the blocks leads to a piecewise parabolic line of action for the compression force.
