dwdoyle8854
- 16
The statement of the question is:A chain of uniform linear mass density ##\rho##, length ##b## and mass ##M## hands as shown in the figure below. At time t=0, the ends A and B are adjacent, but end B is released. Find the tension in the chain at point A after end B has fallen a distance x by using energy conservation.
Refer to the figure:
http://i.stack.imgur.com/RGmud.jpgI can solve this example (from Marion and Thornton Classical Dynamics 5e) easily from assuming a free fall and summing force. I however do not follow the example's solution using conservation of energy.The example states:We treat the chain as one-dimensional motion ignoring the small horizontal motion. Let the potential energy ##U## be measured relative to the fixed end of the chain so that the initial potential energy ##U(t=0)= U_0 = -\rho g b^2 /4##. A careful geometric construction shows that the potential energy after the chain has dropped a distance ##x## is##U=-\frac{1}{4} \rho g (b^2 +2bx - x^2)##I can reproduce the initial potential energy via integration, that is to say, with ##U(x=0)=0####U=2mgh=2g\rho \int_{\frac{b}{2}}^{0} x dx =- \rho g b^2 /4##but am still unable to reproduce the falling chain potential. Can anyone help me derive the expression for the potential energy as the chain falls,
##U=-\frac{1}{4} \rho g (b^2 +2bx - x^2)##Thank you.
##U=mgh##The Attempt at a Solution
Let ##U(x=0) = 0##. The initial potential is derived above. When the chain falls by an amount x on the B side, the same length ##x## is added to the A side.On the ##A## side:##U=mgh = g \rho \int_{\frac{b}{2} + x}^{0} x dx = -\frac{g\rho (x+b/2)^2}{2}##Similarly, on the ##B## side:##U=mgh = g \rho \int_{\frac{b}{2} - x}^{x} x dx =\frac{g \rho [ x^2 - (b/2 -x)^2 ]}{2}##We next sum these two expressions yielding:##U = \frac{-g\rho (x+b/2)^2 + g \rho [ x^2 - (b/2 -x)^2 ]}{2}##which, after expanding we see the ##bx## terms cancel, and therefore does not reproduce the solution
