Classical Mechanics: Forces on two cylinders
The discussion focuses on a physics problem involving two identical cylinders in a rigid box, emphasizing the forces acting on each cylinder. Participants analyze the forces due to gravity and contact interactions, noting that the cylinders experience equal and opposite forces at their contact point. The main challenge arises in calculating the force R acting on the uppermost cylinder, particularly in determining the angle θ related to the box's dimensions. A geometric approach is suggested to relate the angle to the box's width and cylinder radius. The conversation concludes with one participant successfully resolving the issue with the provided guidance.
Saennir
Two identical, uniform and rigid cylinders, each of radius a and mass m, are laid horizontally at rest inside a rigid box of width w. There is no friction acting at any of the four contacts.
i) Draw a diagram for each cylinder showing the forces acting on it alone, using labels to show which forces, if any, have the same magnitudes. Justify your assignments.
ii) Show that the force R acting upon the uppermost cylinder at the contact point the cylinders is given by R=\frac{mg}{\sqrt{(2(w/2a)-(w/2a)^2)}}
The problem + diagram are shown in the following imgur link. (Parts a and b were unrelated)
http://imgur.com/HCzNA
The first section of the problem seemed relatively straightforward: the left and right cylinder both have the same downwards force acting on them due to gravity, as well as contact forces between them equal in magnitude but opposite in direction, pointing towards the centre of each cylinder, given in part 2 as R. The cylinder on the left also has reaction forces from the bottom and side of the box, and the cylinder on the right has a reaction force from the side on the right.
I mainly had trouble with the second part of the problem: I understand that for the uppermost cylinder the vertical component of R is equal to the force acting on the cylinder due to gravity, so Rsinθ = mg, and thus R = mg/sinθ. However, I'm unsure of how to find the angle/determine sinθ using the dimensions of the box, w and a.
I thought I could possibly solve it using certain situations, ie when w = 2a, R = mg, and when w = 4a, R = 0, but I wasn't sure if that was the right approach or how to continue.
Thanks for any help.
Hi Saennir, welcome to PF.
Consider the geometry of the problem in the figure attached. You certainly can find how the angle is related to the dimensions of the box.
ehild
Ah, I see. Yeah, I solved it using that, thanks a lot.
Thanks for the welcome!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
