Classical Oscillator Resonance: Understanding & Amplification
  • Thread starter Thread starter samreen
    Amplification
Resonance occurs in a classical oscillator when the system is configured to absorb maximum energy, resulting in amplification of oscillatory motion. This phenomenon can be demonstrated with a pendulum experiment, where consistent strikes at the same point in the pendulum's motion enhance its swing due to the reinforcement of energy packets. Conversely, striking at the wrong moment can dampen or halt the oscillation. Understanding resonance involves recognizing how energy transfer is maximized at specific frequencies. Further reading on second-order linear ODEs and resonance systems is suggested for deeper insights.
samreen
for a classical oscillator. i kno when resonance happens. what i don't know is WHAT happens in resonance. and WHY it happens. I am very sketchy bt the details...is resonance happening when the system is oriented or configured to b able to absorb max energy? why the amplification? could u suggest reading material?
Make sure you know how to solve second-order linear ODE with constant coefficients
If not,don't bother to think why
ive dun the math...for free, damped and forced. trouble is, it feels like math.not physics. which is what I've asked.
I agree wholeheartedly. a Physicist should be able to explain most things without resort to complicated maths.
Try this: Either as a thought experiment or a real one.
Hang a very heavy weight to act as a pendulum.
Take your handkerchief and tie a knot in the end.
Attack the pendulum with your knotted kerchief by hitting the weight repeatedly with the knot, always in the same direction.
You will find that if you strike at random intervals, the pendulum will scarcely move.
If however you always strike at the same point in the motion of the pendulum the blows will add up and the oscillatory motion will increase.
Eventually you will be able to get a good steady swing going.
This is resonance (at very low frequency so you can see what is happening).
The weight is accepting small packets of energy at its resonant frequency. All these packets are reinforcing one and other so energy transfer is high.
You can also upset the oscillation by striking at the wrong moment - when the pendulum is going towards the knot. Do this enough times and you will slow or stop the oscillation.
If you want to demonstrate damping in this experiment use a piece of sponge rubber on a string. The sponge will introduce damping.
thanx guys...makes a load of sense now
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Does Poisson's equation hold due to vector potential cancellation?'
Imagine that two charged particles, with charge ##+q##, start at the origin and then move apart symmetrically on the ##+y## and ##-y## axes due to their electrostatic repulsion. The ##y##-component of the retarded Liénard-Wiechert vector potential at a point along the ##x##-axis due to the two charges is $$ \begin{eqnarray*} A_y&=&\frac{q\,[\dot{y}]_{\mathrm{ret}}}{4\pi\varepsilon_0 c^2[(x^2+y^2)^{1/2}+y\dot{y}/c]_{\mathrm{ret}}}\tag{1}\\...
