A Classifying quarks and leptons using LCTs representation
Mich24
TL;DR Summary
About the way of classifying quarks and leptons using linear canonical transformations spin representation.
Hello everyone, I would like to ask for opinions/expertises about the way of classifying quarks and leptons using linear canonical transformations spin representation as explainedin this link https://en.m.wikipedia.org/wiki/Linear_canonical_transformation
Are the statements true ?
Please find attached a picture from the link that gives some description.
Thank you in Advance
This is some kind of speculative unified theory... There are innumerable examples in theoretical physics, in which the properties of particles are used to group them into speculative taxonomies hinting at new physical laws. Sometimes this works and leads to an actual discovery, sometimes it doesn't, sometimes it can't work, sometimes it's still undecided.
I do not recognize this particular scheme (it appears to be the work of a group of researchers from Madagascar), but on closer inspection it could turn out to be a variation on something well-known. If anyone does want to get to the bottom of it, they could try this 2018 paper by the same people, in which it is described as based on a combination of "phase space symmetry" with the usual "internal symmetries" of gauge theory.
Thank you for answer.
Could you please elaborate a little more on the part where you said "on closer inspection it could turn out to be a variation on something well-known"
thank you again.
I might start by trying to understand their use of Clifford algebras, and their use of phase space symmetries. Then I could look for precedents in the literature.
I understand, Please let me know if you find anything in this direction. Thank you again. I remarked (from the picture) that they use the generators of the Clifford algebra to define some kind of ladder operators: I don't know if it is something usual or known.
This is an alert about a claim regarding the standard model, that got a burst of attention in the past two weeks. The original paper came out last year: "The electroweak η_W meson" by Gia Dvali, Archil Kobakhidze, Otari Sakhelashvili (2024) The recent follow-up and other responses are "η_W-meson from topological properties of the electroweak vacuum" by Dvali et al "Hiding in Plain Sight, the electroweak η_W" by Giacomo Cacciapaglia, Francesco Sannino, Jessica Turner "Astrophysical...
In LQG and LQC there are solutions called "black to white transition". I'll add some references: (Rovelli)https://arxiv.org/abs/1905.07251 (Rovelli)https://arxiv.org/abs/2302.03872 (Rovelli)https://arxiv.org/abs/1803.06330 (Rovelli)https://arxiv.org/pdf/1802.04264 (Rovelli)https://arxiv.org/abs/2108.12823 https://arxiv.org/abs/2304.02691 https://arxiv.org/abs/2110.07589 https://arxiv.org/abs/2009.01788 https://arxiv.org/abs/1911.12646 https://arxiv.org/abs/1801.03027...
Hello everyone, I am seeking to better understand the conceptual foundations and potential consequences of "Two-Time Physics" (2T-physics), as developed by Itzhak Bars and others. My interest was sparked by a recent paper that attempts to explain anomalous results in particle physics (apparent superluminal propagation of virtual photons) within the framework of 2T-physics: Paper: https://arxiv.org/abs/2408.02696 Key quote from the abstract: *"...the problem... can be solved naturally...
