Climate Change: Why Doesn't Rising Temperature Balance Out?
In summary: The atmosphere is made up of different layers: the troposphere, stratosphere, mesosphere, and thermosphere. The troposphere is the layer closest to the Earth's surface. The stratosphere is the layer in the atmosphere between the troposphere and the thermosphere. The mesosphere is the layer in the atmosphere between the stratosphere and the thermosphere. The thermosphere is the layer in the atmosphere between the mesosphere and the exosphere.
markulmer
First, I am not a scientist, so this may be a stupid question. But with all the concern about global warming - and given that temperature and pressure are related - why doesn’t rising temperature cause the atmosphere to expand outward and the temperature to fall as a result, back to an equilibrium? After all, Earth is surrounding by the vacuum of space.
Welcome to PF!
The answer is: it does! And not just due to global warming, but due to weather and solar activity.
Interestingly, google tells me that overall global warming will (has?) cause the atmosphere to contract because the warming happens low in the atmosphere, which then causes cooling in the upper atmosphere:
http://www.ucar.edu/news/releases/2006/thermosphere.shtml
Likes jim mcnamara
https://en.wikipedia.org/wiki/Skylab
Came down rather earlier than NASA expected due 'solar cycle' inflating upper atmosphere and significantly increasing drag.
Upside of this effect is each 'Solar Max' clears a lot of debris from low orbit. Down-side is we may be facing a 'long minimum'...
To help understand it's important to remember the atmosphere is about 300 miles thick. To put that in perspective the international space station orbits at 254 miles, so it's technically not even in outer space yet. Though the vast majority of the atmosphere is kept much closer. So the density changes a lot which also has an effect on temperature.
It's important to understand that a high temp and heat are not exactly the same. Temperature indicates how quickly atoms are moving. Heat indicates it's impact on the body. As you go up in altitude it gets colder decreasing in temp. But when you hit the stratosphere the composition of air changes and temp actually starts to increase. At the top of the stratosphere the temp is basically the same as ground level. But the air is so thin that high you'd still freeze to death.
So if the atmosphere were a uniform gas it would expand and contract due to temp such as you'd see in air in a balloon. But the atmosphere is a bit more complicated and requires further explanation.
Related to Climate Change: Why Doesn't Rising Temperature Balance Out?
1. Why are temperatures rising if the Earth's climate is constantly changing?
While it is true that the Earth's climate has always been changing, the current rate of temperature increase is much faster than natural climate variability. This is largely due to human activities such as burning fossil fuels, deforestation, and agricultural practices that release large amounts of greenhouse gases into the atmosphere. These gases trap heat and contribute to the warming of the planet.
2. Can't the Earth just adapt to rising temperatures on its own?
The Earth does have natural mechanisms for regulating its temperature, such as the carbon cycle and the ocean's ability to absorb heat. However, these natural processes are not equipped to handle the rapid rate of temperature increase caused by human activities. This can lead to severe consequences such as sea level rise and more intense natural disasters.
3. I've heard that some areas are actually getting colder, so does that mean climate change isn't real?
While some regions may experience temporary cooling due to natural fluctuations in weather patterns, the overall trend is towards warming. Global average temperatures have been steadily increasing since the Industrial Revolution, and this warming trend is consistent with the predicted effects of climate change.
4. What about the argument that the Earth has gone through natural cycles of warming and cooling in the past?
It is true that the Earth has experienced changes in temperature over millions of years due to natural cycles. However, the current warming trend is happening at a much faster rate than any natural cycles in the Earth's history. Additionally, extensive scientific evidence shows that human activities are the primary cause of this current warming trend.
5. If rising temperatures are caused by human activities, can't we just stop those activities to reverse the effects of climate change?
While reducing greenhouse gas emissions is crucial in mitigating the effects of climate change, the damage that has already been done will continue to affect the Earth's climate for years to come. It is important to take immediate action to reduce our carbon footprint, but we must also adapt to the changes that are already happening and work towards creating a more sustainable future.
12K
  • Science Fiction and Fantasy Media
12K
  • General Discussion
  • Earth Sciences
  • Earth Sciences
  • Earth Sciences
23K
