Coefficient of kinetic friction forces
To find the applied force for an object with a coefficient of kinetic friction of 0.30 and an acceleration of 5 m/s², the normal force must be calculated correctly, as it does not equal mg in this scenario. A force diagram is essential to visualize all forces acting on the object, including the applied force at a 40-degree angle, friction, normal, and gravitational forces. The frictional force is calculated as Ff = (0.3)(10)(9.8) = 29.4 N. The net force equation, Fnet = Facos40 - Ff, must be used to solve for the applied force accurately. Understanding the components of forces is crucial for arriving at the correct solution.
yoyo16
Find the applied force for a object if the coefficient of kinetic friction equals 0.30 and the acceleration equals 5m/s^2. The applied force makes a 40 degree angle with the horizontal. The mass of the object is 10kg.
Fnet=ma
Ff=(0.3)(10)(9.8)=29.4
(coefficient)(normal force=mg)
Fnet =Facos40-29.4
Fnet=ma
ma=Facos40-29.4
Fa=103.6
I don't know if I did this right. Can someone please explain to me how to do this correctly. Thanks!
If I understand the question correctly, the above is not correct. That is, normal force does not equal mg in this case, rendering the rest of your calculations incorrect.
I'd start by drawing a force diagram and clearly labeling ALL the forces acting upon the object.
So how would you find out the friction force without knowing the normal force?
Draw a force diagram. The problem states that the applied force makes a 40 degree angle with horizontal. Draw that force vector, along with friction force, normal force and gravitational force.
After doing so, figure out the y-component and x-component of the net Force. Start with the y-component. What are all the upward and downward forces acting upon the object?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
