Coefficient of kinetic friction of a block
This is because the coefficient of kinetic friction, Mk, is a type of friction that depends on the material properties of both surfaces in contact. Therefore, the correct answer is (e) what the 2 materials are made of. In summary, the coefficient of kinetic friction of a block depends on the material properties of both surfaces in contact, making the correct answer (e) what the 2 materials are made of.
landry
Mk
The coefficient of kinetic friction of a block depends on:
A. normal force.
B. surface area of the 2 materials
c. mass of block
d. speed of block
e. what the 2 materials are made of
SInce friction of a block depends on what the 2 materials are made of then i believe the answer would be E since Mk is a type of friction
A. normal force.
c. mass of block
d. speed of block
Among the choices available, I'd agree that (e) is correct.
that occurs when two surfaces are in contact and moving relative to each other. The materials that make up the surfaces can affect the roughness and adhesion between them, which in turn affects the coefficient of kinetic friction. For example, surfaces made of rubber and glass will have a different coefficient of kinetic friction compared to surfaces made of rubber and steel. Therefore, the answer would be E.
FAQ: Coefficient of kinetic friction of a block
What is the coefficient of kinetic friction?
The coefficient of kinetic friction is a measure of the resistance between two surfaces in contact when one is in motion. It is represented by the symbol μk and is a dimensionless value between 0 and 1.
How is the coefficient of kinetic friction calculated?
The coefficient of kinetic friction is calculated by dividing the force of kinetic friction by the normal force between the two surfaces. The formula is μk = Fk / Fn.
What factors affect the coefficient of kinetic friction?
The coefficient of kinetic friction is affected by the nature of the two surfaces in contact, the roughness of the surfaces, and the amount of force applied.
How does the coefficient of kinetic friction differ from the coefficient of static friction?
The coefficient of kinetic friction is the measure of the resistance between two surfaces in motion, while the coefficient of static friction is the measure of the resistance between two surfaces at rest. The coefficient of kinetic friction is typically lower than the coefficient of static friction.
Why is the coefficient of kinetic friction important?
The coefficient of kinetic friction is important because it helps determine the amount of force needed to keep an object in motion on a surface. It also plays a role in understanding the efficiency of machines and the design of moving parts.
