Coefficient of kinetic friction on 2 different parts
The discussion focuses on calculating the coefficient of kinetic friction for a mass sliding down an incline and then traveling horizontally. The initial speed is given as 2.17 m/s, and the mass travels specific distances on both the incline and horizontal sections before stopping. The participants emphasize the need to apply energy conservation principles, considering both potential and kinetic energy changes, along with work done against friction. They clarify that the mass retains some velocity at the end of the incline, which is crucial for determining the friction coefficient. The conversation highlights the importance of setting up equations that relate kinetic energy to work done by friction to solve for the unknowns.
yannguyen
When the mass M is at the position shown, it has a speed v0 = 2.17 m/s and is sliding down the inclined part of a slide. The mass reaches the bottom of the incline and then travels a distance S2 = 2.45 m along the horizontal part of the slide before stopping. The distance S1 = 1.11 m and the angle of the incline is θ = 31.1o. Calculate the coefficient of kinetic friction for the mass on the surface.
E= KE + U
E+ W (ext) = 0 -> E = -W (ext) (which is the work done by frictional force)
So far I've analysed the x and y components of the mass on path S1 and path S2. This is what I've got
Path S1:
y-dir: N = mgcosθ
x-dir: ƩF = -F(friction) + mgsinθ = -μmgcosθ + mgsinθ
So W1 ( work done on S1) = S1(-μmgcosθ + mgsinθ)
Path S2:
W2 = -μmg(S2)
Since -W (total) = E
W1+W2 = KE + U (at original position)
S1(-μmgcosθ + mgsinθ) - μmg(S2) = - [(1/2)mv2 + mgS1sinθ]
μ(S1gcosθ + gS2) = 2S1gsinθ + v2/2
μ = (2S1gsinθ + v2/2)/(S1gcosθ + gS2)
So far I've got μ = .105 but it's wrong!
I'd really appreciate if anyone helped me out with this cos I totally have no idea how to figure out the right answer!
You can begin with part 2 and write an equation that relates the velocity at the bottom of the hill to the distance covered until it stops on the horizontal. To do this, relate the KE (including unknown V at bottom of part 1) to the work done overcoming friction. That gives you an equation with two unknowns, V and mu. There are no potential energy changes when moving horizontally.
Look at part 1 and write your energy balances. This will give you another equation with two unknowns, again being V and mu. This time you have to consider potential and kinetic energy changes as well as work. Eliminate V and solve for mu.
I'm not sure if i got u right. Does that mean that on part 1 that i have the potential energy change and the change in the KE too? (the velocity at the end of S1 is not 0?) and then on part 2 I just have the change in kinetic energy, which also equals to the work done by frictional force on S2?
Correct. The mass has an initial velocity and it will also have a final velocity that is different and unknown but it is the initial velocity for part 2. The initial velocity at the start of part 1 is given.
On part 2 the kinetic energy change is what it was at the end of part 1 and zero and it equals the work done against friction.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
