Coefficient of static friction on a ramp?
To find the coefficient of static friction between the block and the plank, the problem involves analyzing a triangle formed by the ramp's height and length. The relevant equations include F = ma and fs = mus x FN, where FN is the normal force. The mass of the block is not provided, but it can be treated as an unknown "m" to simplify calculations, as it will cancel out in the algebra. The discussion emphasizes working symbolically to derive the solution. Understanding the application of these equations is crucial for solving the problem effectively.
katie beisel
A small block sits at the midpoint of a 2.0 m plank lying on a level floor. A student slowly raises one end of the plank until the block starts to slide. At that instant, the raised end is 0.55 m above the floor. Find the coefficient of static friction between block and plank.
F = ma
fs = mus x FN
so i turned it into a triangle and the sides are 1.9, .55, 2.0
theres no mass given so I'm not sure how to even begin to find the force of friction or force normal
Work symbolically. Leave the mass as an unknown "m" and work through the algebra. You should find that the m will cancel out along the way.
Likes katie beisel
i don't understand. using what equation?
What equations would you apply if the mass were given?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
