Coefficients for an exponential Fourier Series
ElPimiento
I'm kinda just hoping someone can look over my work and tell me if I'm solving the problem correctly. Since my final answer is very messy, I don't trust it.
1. Homework Statement
We're asked to find the Fourier series for the following function:
f(\theta)=e^{−\alpha \lvert \theta \rvert}}, \ \ \ \text{for} −\pi<\theta<\pi,
where ##f(\theta + \pi) = f(\theta)##. Except our Fourier series has the form:
f(\theta) = \sum_{-\infty}^{\infty} c_n e^{in\theta}
Variation on Euler:
\cos{\theta} = \frac{1}{2}(e^{i\theta} + e^{-i\theta})
Vector projection:
proj_\vec{v}(\vec{u}) = \frac{\langle\vec{v}, \vec{u}\rangle}{\langle\vec{v}, \vec{v}\rangle}
So, supposing ##n## is an Integer, I First realized that every positive ##n## has a negative partner, hence our special Fourier series formula can be rewritten as
\begin{align*}
& = c_0 + \sum_{-\infty}^{-1} (c_{n^{(-)}} e^{in\theta}) + \sum_{1}^{\infty} (c_{n^{(+)}} e^{in\theta}) \\
& = c_0 + \sum_{-\infty}^{\infty }k_n (e^{in\theta} + e^{-in\theta}) \\
& = \sum_{-\infty}^{\infty} k_n \cos(n\theta) \\
\end{align*}
Where I have used the variation on Euler's Equation (above) and set ##k_n = (c_{n^{(-)}} + c_{n^{(+)}})/2##.
Then using the inner product:
\langle f(x), g(x) \rangle = \int_{-\pi}^{\pi} dx f(x) g(x)
I found that the coefficients should be:
\begin{align*}
k_n & = \frac{\langle e^{-\alpha \lvert \theta \rvert}, \cos(n \theta) \rangle}{\langle \cos(n \theta), cos(n \theta)\rangle} \\
& = \frac{\int_{-\pi}^{\pi} e^{-\alpha \lvert \theta \rvert} cos(n \theta)} {\int_{-\pi}^{\pi} cos^2(n \theta)} \\
& = \frac{\int_{0}^{\pi} e^{-\alpha \theta} cos(n \theta)} {\int_{0}^{\pi} cos^2(n \theta)} \ \ \ \ \ (\because \text{all the functions are even}) \\
& = - \frac{4 n (\frac{\alpha \cos(\pi n) - n \sin(\pi n)}{(\alpha^2 + n^2)e^{(\pi \alpha)}} - \frac{\alpha}{\alpha^2 + n^2} )} {2 \pi n + \sin(2 \pi n)} \\
\end{align*}
Which is a mess.
I used cosines hoping it would simplify the problem (since they're even and the resulting series starts at 0 instead of ##-\infty##), but it doesn't look like it did much good. So is the method at least right?
Variation on Euler:
Vector projection:
\begin{align*}
\end{align*}
\begin{align*}
\end{align*}
Which is a mess.
Why don't you simplify ##\cos(\pi n), \sin(\pi n)## and ##\sin (2 \pi n)##? Remember that ##n## is an integer.
When you do that you get a result that agrees with that obtained using Maple.
Likes ElPimiento
Oh duh, I should've realized that >~<.
Thanks though! That cleaned it up nicely:
k_n = -\frac{2 \alpha (e^{\pi \alpha} - 1)}{\pi (\alpha^2 + n^2)}
Woops! got a little too excited with the cancelation:
\begin{align*}
k_n
& = -\frac{2 \, {\left(\frac{\left(-1\right)^{n} \alpha}{\alpha^{2} e^{\left(\pi \alpha\right)} + n^{2} e^{\left(\pi \alpha\right)}} - \frac{\alpha}{\alpha^{2} + n^{2}}\right)}}{\pi} \\
& = - \frac{2 \alpha ((-1)^n e^{- \pi \alpha} - 1)}{\pi (\alpha^2 + n^2)} \\
\end{align*}
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
