A Coefficients of Chebyshev polynomials
gty656
Not long ago, I derived the formula for Chebyshev polynomials
$$T_{n}\left( x\right)= \sum_{k=0}^{\lfloor \frac{n}{2} \rfloor}{n \choose 2k}x^{n-2k}\left( x^2-1\right)^{k}$$
How to extract the coefficients of this polynomial of degree n ?
I tried using Newton's binomial but got a double sum
$$\sum_{k=0}^{\lfloor \frac{n}{2} \rfloor}{n \choose 2k}x^{n-2k}\left( \sum_{m=0}^{k} {k \choose m} x^{2m}\left( -1\right)^{k-m} \right) \\
\sum_{k=0}^{\lfloor \frac{n}{2} \rfloor}\sum_{m=0}^{k}\left( -1\right)^{k-m} {n \choose 2k} \cdot {k \choose m} x^{n+2m-2k}\\
Now how to continue counting this sum ?
What would it look like to change the order of summation and would it do anything ?What else did I try ?
Well, I worked out the sum
$$\sum_{k=0}^{\lfloor \frac{n}{2} \rfloor}{n \choose 2k}x^{n-2k}\left( x^2-1\right)^{k} $$
for n=8
and I hypothesized that
$$T_{n}\left( x\right)= \sum_{k=0}^{\lfloor \frac{n}{2} \rfloor} \sum_{m=k}^{\lfloor \frac{n}{2} \rfloor}\left( -1\right)^{k}{n \choose 2m} \cdot {m \choose k} x^{n-2k} $$
However, it would be useful to demonstrate the correctness of this hypothesis and count the sum of
$$\sum_{m=k}^{\lfloor \frac{n}{2} \rfloor}{n \choose 2m} \cdot {m \choose k}$$
Here I would like to point out that Wolfram Alpha counts this sum incorrectly
$$\sum_{m=k}^{\lfloor \frac{n}{2}\rfloor}{{n \choose 2m} \cdot {m \choose k}} = \frac{n}{2n-2k} \cdot 2^{n-2k} \cdot {n - k \choose k}$$
And it would even be a nice result but
first of all it is not quite correct ( Have you noticed why ?)
and secondly it comes from a hypothesis I made after dissecting the formula for $n=8$.
It seems to me that this hypothesis of mine would be enough to prove by induction after n but how would it look?​
This appears to be a correct representation of ##T_{n}\left( x\right)##, checked by explicit calculation of the factors for various values of ##n##.
Mathematica gives a complicated answer in terms of the gamma and hypergeometric functions, so there doesn't appear to be a simple closed formula.
I checked for myself in Wolfram some initial values for n
and it was ok however I would like to see a full proof with induction being enough for me
(When proving the induction step, you will probably need to refer to the definition of recursion
except that here we have second-order linear recursion)As for this sum, in my case Wolfram calculated it as follows
## \sum_{m=k}^{\lfloor\frac{n}{2}\rfloor}{n \choose 2m} \cdot {m \choose k} = \frac{n}{2n-2k} \cdot {n - k \choose k} \cdot 2^{n-2k}##
However, I noticed that the problem would be, for example, n=0.
I thought it was possible to find a similar formula to the above however also correct for n=0.
I would also like to add that there is a slight error in my post namely in the second line it should look like this in sequence:
##\sum_{k=0}^{\lfloor \frac{n}{2} \rfloor}{n \choose 2k}x^{n-2k}\left( \sum_{m=0}^{k} {k \choose m} x^{2m}\left( -1\right)^{k-m} \right) \\##​
##\sum_{k=0}^{\lfloor \frac{n}{2} \rfloor}\sum_{m=0}^{k}\left( -1\right)^{k-m} {n \choose 2k} \cdot {k \choose m} x^{n+2m-2k}\\
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
