Collision physics homework help
In a collision problem involving a car and a truck, both vehicles lock together and move at 28 m/s at an angle of 38° north of east after the collision. To find the car's initial speed, momentum conservation principles must be applied in both the x and y directions. The momentum equation can be set up as (m1 + m2)*vfx = m1*vix + m2*v2x, where the masses are equal and cancel out. The y-direction momentum can be expressed as M*vcar = 2M*28sin38, allowing for the calculation of the car's initial velocity. This approach effectively demonstrates how to solve for the car's speed using dynamics and momentum conservation.
tandoorichicken
A car heading north collides at an intersection with a truck heading east. If they lock togethr and travel at 28 m/s at 38° north of east just after the collision, how fast was the car initially traveling? Assume that the vehicles have the same mass.
Does this problem not depend on how fast the truck was traveling also?
It does, but I think you can solve for it using dynamics once you have the right momentum equation set up.
I am not sure what you would do to set up for it though, but i think you would start with (m1 + m2)*vfx = m1*vix + m2 *v2x,
and do another one for the y-direction. Since mass is the same, I'd assume that final velocity in each direction is the initials in that direction added together, but i am not sure on that.
Not sure of the dynamics equation either, but I'd try that.
If I'm not mistaken, then the momentum in the y direction is going to be equal before and after the collision, so you can set up an equation like
M*vcar = 2M*28sin38
2M on the right side because the vehicles are the same mass... the M's cancel and you can solve for vcar.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
