Colour of inox steel surface upon heating
In summary, when heating inox steel in the presence of air, the metal surface will change color as the temperature increases. This is due to the formation of oxide layers of different thickness, with the thickness being the key factor in determining the color. The different thicknesses of the oxide layers cause different scattering or interference, leading to the change in color. However, the color does not change with the angle of observation, suggesting that the interference is not the sole factor responsible for the phenomenon.
lightarrow
1,965
61
If you heat inox steel in presence of air, up to a specific temperature, you get a yellow colour of the metal surface; increasing the temperature it becomes red; still increasing, blue.
Is it due to the formation of oxide layers of different thickness? Which effect is responsible of the colour?
Thickness (number of layers) of the oxide is the key factor. Different thicknesses produce different scattering or interference.
http://www.bssa.org.uk/topics.php?article=140
http://www.tpub.com/steelworker1/11.htm
Thank you Astronuc.
If the interference is responsible of the phenomenon, why the colour doesn't change with the angle of observation?
Related to Colour of inox steel surface upon heating
1. What causes the color change in inox steel when heated?
The color change in inox steel when heated is caused by a process called oxidation. This is when the iron atoms on the surface of the steel react with oxygen in the air to form iron oxide, also known as rust. The amount of oxygen present and the temperature of the steel can affect the color of the oxide layer formed.
2. Why does inox steel turn blue when heated?
Inox steel turns blue when heated due to a process called tempering. This is when the steel is heated to a specific temperature and then cooled, which changes the arrangement of the atoms in the steel. The blue color is caused by the formation of a thin layer of iron oxide on the surface of the steel.
3. Can the color of inox steel be controlled when heated?
Yes, the color of inox steel can be controlled when heated by adjusting the temperature and duration of the heating process. Different temperatures and durations can result in different colors, such as blue, gold, or even purple. This is commonly used in decorative applications for inox steel.
4. Is the color change in inox steel reversible?
The color change in inox steel due to heating is not reversible. Once the steel has been heated and the oxide layer has formed, it cannot be removed without damaging the steel surface. However, the process can be repeated to achieve a different color if desired.
5. Does the color of inox steel affect its properties?
The color of inox steel does not significantly affect its properties. However, the formation of an oxide layer on the surface can provide some protection against corrosion. Additionally, the heating process may alter the hardness and strength of the steel, depending on the temperature and duration used.
  • Mechanical Engineering
  • Materials and Chemical Engineering
  • Atomic and Condensed Matter
