MHB Combination of field and particle methods for fluid dynamics
Numerical fluid dynamics utilizes field methods like finite-volume and finite-element approaches, alongside particle methods such as Smoothed-Particle-Hydrodynamics (SPH). A proposed combination of these methods involves using Voronoi-Diagrams, where Voronoi cells act as particles that adhere to physical laws like conservation of momentum and energy. This hybrid approach could enhance the accuracy of simulations, particularly for turbulent flows that are challenging to predict. However, there is a lack of established numerical methods to effectively implement Voronoi particles in fluid dynamics. Collaboration or guidance in developing such methods is sought from experts in numerical mathematics.
scienceguru2
hello,
in numerical fluid dynamics there are field methods like finite-volume, finite-element, etc. and particle methods like Smoothed-Particle-Hydrodynamics – SPH and others. Both approaches have advantages and disadvantages depending on the application. Both, in principal completely different approaches can be combined using a Voronoi-Diagram. These Voronoi-Cells which behave like particles fill out the complete regarded space and are moving according to the physical laws (conservation of momentum and energy; see also
http://ivancic.de/cfd2k/WhatIsCFD2k.html). These particles also can interact with each other (exchange of momentum, energy, etc. ==> the Voronoi cells/particles obey the Navier-Stokes Equations). Such a Voronoi approach can combine the advantages of field and particle methods and therefore lead to better results in the numerical fluid dynamics (e.g. for turbulent flows which cannot be predicted accurately up to now).
Unfortunately I do not know any numerical method to apply it for such Voronoi-Particles in order to describe physical flows correctly. Does anybody know such a numerical method or is interested to develop such a method together with me? I am an aerospace engineer very familiar with fluid dynamics, turbulence and their physical and thermodynamic laws but sadly I am not an expert in numerical mathematics which is necessary to derive such a new approach.
thanking you in anticipation
Mathematics news on Phys.org
scienceguru2 said:
hello,
This sounds like a research-level mathematics question, and, as such, I would refer you to Math Overflow. It's a site much better suited to your question, I think.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
