B Commutative & Associative property of negative numbers
The discussion focuses on the commutative and associative properties of addition, specifically regarding negative numbers. It confirms that the commutative property holds for addition, as demonstrated by examples like -5 + 7 = 2 and 7 + (-5) = 2. Subtraction is clarified as an operation that doesn't exist in the same way, being a form of addition with inverses, which can lead to confusion. The associative property is also validated through various scenarios involving negative and positive integers. Ultimately, the sign of the numbers does not affect these properties, emphasizing that subtraction is merely an abbreviation for addition of inverses.
sonadoramante
TL;DR Summary
Commutative & Associative property of addition of negative numbers.
Commutative property of addition.
If a & b are integers then,
a+b = b+a
2+3 = 3+2
5.
Does not work for subtraction.
2-3 = -1
3-2= 1
Having said that, what about the special case with negative numbers (when we also move their respective signs)
-5 + 7 = 2 & 7 + (-5) = 2.
15 -7 = 8 & -7 + 15 = 7.
Associative property of addition.
If a, b & c are integers then,
a + (b+c) = (a+b) + c
2 + (3+4) = (2+3) + 4
2+7 = 5+4
9.
I tried 5 scenarios for the above,
a= - b = + c= -
a= + b= - c=+
a=+ b=+ c=-
a=- b=- c=+
a=- b=- c=-
And they all seem to work. It also seems to work for negative numbers in multiplication as well.
Is there a special case for commutativity & associativity for negative numbers?
Mathematics news on Phys.org
The only reason it does not work is the wrong understanding of subtraction. On the level of group axioms which you used as language here, subtraction does not exist as binary operation. It is the unary operation of inversion: ##x \longmapsto x^{-1} := -x##. What you call subtraction is actually an addition: ##(x,y)\longmapsto x+ (-y)##. It is commonly written as ##x-y##, but this is only an abbreviation which causes confusion if used as in your question.
Likes hmmm27 and sonadoramante
Makes perfect sense! Thanks.
Besides the group axioms that fresh_42 mentioned, there are other mathematical structures such as rings, integral domains, and fields, all of which have two binary operations: addition and multiplication. Subtraction isn't included as one of the operations.
However, we can define ##a - b## as ##a + (-b)##, where ##-b## is the additive inverse of ##b##. Then ##a + (-b) = (-b) + a##, and ##a + (-b + c) = (a + (-b)) + c##, so we have commutivity and associativity
The sign of the numbers doesn't enter into things.
Likes sonadoramante
Further, the fact that you happen to put a minus sign in front of something does not make it negative. -(-1) is positive.
In some domains there is not even a notion of "positive" or "negative". For instance, the integers modulo 3 where 2 = -1.
Likes sonadoramante
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
