High School Can the Diagram in the Article Be Interpreted as Commutative?
The discussion centers on interpreting a diagram from an article regarding commutative diagrams in mathematics. The participants note that in typical commutative diagrams, vertices represent mathematical objects and edges represent mappings. They explore whether the diagram's vertical arrows can be understood as mappings from a map to its argument, with all arrows indicating transitions between elements. An unnamed isomorphism is suggested to map elements of a direct sum of quotient modules to vectors in a vector space. The unique visual features of the arrows, including their perpendicular tails, are highlighted as significant for understanding the diagram's structure.
Stephen Tashi
Education Advisor
TL;DR
Does the given example of commutative diagram use conventional notation?
I'm used to seeing commutative diagrams where the vertices are mathematical objects and the edges (arrows) are mappings between them. Can the diagram ( from the interesting article https://people.reed.edu/~jerry/332/25jordan.pdf ) in the attached photo be interpreted that way?
In the article:
##k[x]## is the ring of polynomials over a field k.
##V## is a vector space.
##T## is a linear transformation on ##V##
I understand ##T## and ##X## as maps, but do the vertical arrows go from a map to the argument of a map?
The arrows (all of them, vertical and horizontal) go from element to element. Their LaTeX code is \mapsto.
I'll understand the vertical arrow on the left this way: There is an (unnamed) isomorphism mapping ##V## to a direct sum of quotient modules. So ##g(x) + <f_i(X)>## is one element of that direct sum and it is in the coset of the ##<f_i(X)>##. So the unnamed isomorphism maps an element of the direct sum to a vector ##v## in ##V##.
the visual clue to what fresh and Stephen are saying is that the arrows have little tails at the beginning which are perpendicular to the arrow.
Likes Stephen Tashi
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 25 ·
  • · Replies 24 ·
