Compaction of solids under weight of water
In summary, the conversation discusses the effect of the size and shape of a container on the settling of particles in water. The debate centers around whether the weight of the water column above the particles causes them to compact and settle differently. Factors such as Zeta Potential and pH can also affect the settling process. The settling of flocs of sub micron particles is discussed, with the understanding that there may be repulsive forces between the particles preventing them from settling completely. The role of the column of water above the particles is questioned, and it is wondered if the particles even experience the weight of the water. The concept is compared to that of ordinary solids, such as sand.
thekingofclubs
Hi there, first time poster here but I've been following the forum for years - what an outstanding resource! Thanks to all who contribute. Hopefully one day I can add my 2 cents.
I have a general question (more of a curiosity) that arose from an observation at work. It has sparked a debate amongst my co-workers which I am hoping to settle.
The ultimate question is whether or not the size of a column of water has an effect on the solids which have settled at the bottom. The debate has come from observing flocs of tiny iron particles settling out of containers of water. The mixture typically settles to approx 1/4 of the initial bulk volume. For example, in a 1 L container, after settling the solids on the bottom are roughly 250 mL with 750 mL of clear water on top.
Someone suggested that in a larger container with more of the initial mixture the weight of the extra water on top of the settled particles causes them to compact tighter, thus changing the relative volume proportions (say 1/5 solids & 4/5 water). Does this make any sense? To me it doesn't because the mud at the bottom of the ocean would be rock hard. Does the actual quantity (volume) of water you start with really have any bearing on the final outcome?
Would the shape of the vessel (tall and narrow vs short and wide) have any effect? Why do people prefer to decant supernatant from tall and narrow vessels? Do the particles settle any faster?
I always thought particle settling was dependent only on buoyancy, gravitational, and drag forces. I remember calculating pressure at various water depths in my education but does that pressure have any effect on the compression/compaction of the solids? What determines how close the particles get to one another or how much water stays between them? At this point is it more of a particle-particle interaction?
We can assume that in each case, the ratio of iron to water in the bulk (mixed) solution before settling is the same.
Any input would be greatly appreciated!
Just consider sediment settling to the bottom of a sea ... after a while it gets compacted enough to turn into sedimentary rock.
So you need the extra weight from the water column, and time.
But is that because of the weight of water? Because of time? Because of the weight of all the other sediment layered on top? Because the interstices between the original sediment particles themselves fill up with sediment?
Consider, instead, a bag of marbles on the sea bed. Does the pressure of all the water above cause the marbles to be crushed into a single spherical clump? No. It does not. It compresses each marble individually.
If you are forming a floc, then the bulk density of the flock must be much lower than if the floc were compacted. What would be the thickness of the precipitate if it was fully compacted, or at least compacted with a void fraction of, say, 50%? Are there electrostatic repulsion interactions between the floc particles involved?
Chet
It gets tricky in this particular case because the particles are actually flocs of sub micron particles. Nano particle behavior as I understand can be a whole different animal. Factors such as Zeta Potential need to be considered. For example a simple pH adjustment can change whether the flocs form and settle, or not. In general it takes several hours for the particles to settle out, and then they continue to settle tighter down for another day or two before finally reaching steady state. As far as their size when completely compacted I really have no idea, as when they are dried there is hardly anything left.
Perhaps this needs to be addressed differently than if it were sand or soil particles, but the concept should be close. Like I say, its more so a curiosity about the potential forces due to the relative column of water above the particles.
Thanks everyone for your input so far!
If this is the case, then there must be repulsive forces between the particles that prevent them from settling all the way. This will not be affected by the column of water above the particles. So the fraction that fill the column after the settling is complete should not be a function of the length of the column.
Chet
Thanks Chet,
So how would things be different if these were ordinary solids such as sand? Does the water overhead actually compact these particles such as in the case of mud at the bottom of a body of water? Do the particles even "experience" the weight of the water above? Or is their separation solely based on the specific gravity between the particles and the fluid?
Thanks Chet,
The latter. There is, of course, a buoyant force on the particles. And each individual particle is compressed slightly by the pressure of the water, but this is typically negligible. As far as the interaction between particles is concerned, for sand or marbles, it's pretty much the same bulk density of solid as if the water was not even there. (For more extreme situations involving large overhead amounts of solid, such as in deep aquifers, you need to employ poroelasticity theory to consider the deformations of the particles and the changes in the void space between particles).
Chet
For an introduction to sedimentary rock formation see: http://gomyclass.com/geology10/files/lecture6/html/web_data/file43.htm
Related to Compaction of solids under weight of water
What is compaction of solids under weight of water?
Compaction of solids under weight of water is the process by which the particles of a solid material are pressed together, reducing the volume of the material, under the influence of the weight of the water above it.
What causes compaction of solids under weight of water?
The weight of the water above the solid material causes the particles to be compressed and pushed closer together, leading to compaction.
What are the effects of compaction of solids under weight of water?
The effects of compaction of solids under weight of water depend on the type of material and the amount of compaction. In general, it can lead to reduced permeability, increased strength, and reduced settlement of the material.
How is compaction of solids under weight of water measured?
Compaction of solids under weight of water is typically measured using a compaction test, such as the Proctor or modified Proctor test. These tests involve compacting a specified amount of material under a specific weight and measuring the resulting density.
What factors can affect compaction of solids under weight of water?
The compaction of solids under weight of water can be affected by various factors such as the type and properties of the material, the weight of the water, the duration of the loading, and the presence of any external forces or stresses.
  • General Engineering
  • Mechanics
  • Mechanics
11K
  • Earth Sciences
