- #71
GeorgeDishman
- 419
- 29
whosapopstar? said:Can anyone please read only the opening message of the thread: "synchronized clocks with respect to rest frame" and answer me this:
Answer #2 in that thread is correct but also note that #3 is an important qualifier.
When the train returns, we can see that somthing happened, e.g. we have time dilation on the clock, and we agree that at least part of that time dilation was produced by constant speed (CS). There is evidence of say "nature 1" that somthing happened there.
There is a cumulative time difference between the clocks that went on the journey and an identical clock that remained on the station. That is the essence of the Twins scenario.
Now regarding the clocks that are not synchronized, although they are both on the same train (but apart from each other):
While moving, they are not synchronised as determined by observer "O" but they are synchronised as determined by observer "R". It is important to specify the observer since simultaneity is frame-dependent.
is there an experiment that can be done, which will show us this difference of de-synchroniztion between them, after the clocks will return to the station (nature 1),
Off-hand, I'm not sure if there is one that addresses synchronisation specifically but the cumulative difference between the train clocks and the station clock was famously tested by Hafele and Keating, while the effect on moving "clocks" was first tested by Ives and Stilwell.
http://en.wikipedia.org/wiki/Hafele–Keating_experiment
http://en.wikipedia.org/wiki/Ives–Stilwell_experiment
It is important if you want to understand this stuff to note that this is not indicative of flaws in the clocks, in the thought experiments they are assumed to be working perfectly at all times and in real experiments, the accuracy of the instruments is adequate to demonstrate the results. What you are supposed to understand from them is that the measurement we call "time" is path-dependent, like the mileage reading from odometers in cars taking different paths between two locations.
