Comparing Illuminance and Solar Radiation in Dragonfly Habitat
The discussion focuses on the challenge of comparing illuminance measured in lux with solar radiation expressed in kJ/m^2 for a GIS modeling project aimed at predicting dragonfly habitat. It clarifies that lux is a unit of illumination based on lumens per square meter, while solar radiation measures energy per area. Converting lux to kJ/m^2 directly is not feasible without making assumptions about the light's wavelength and source. The conversation highlights that both measurements relate to sunlight and energy, which are relevant to dragonfly habitats. Overall, understanding the relationship between these units can enhance the analysis of habitat suitability.
Darcy
Hello,
I'm working on a GIS modeling project where I'm trying to predict dragonfly habitat. I have collected my field data using a hand-held meter that measures illuminance in lux. I am wanting to incorporate some other spatial data I derived using a digital elevation model which shows solar radiation in kJ/m^2.
Is there a way to convert the lux values into kJ/m^2? It's not really necessary for my analysis, but yet would be useful in comparison.
I'm thinking that the two measurements, even if not able to convert can be discussed in the same regard as both are measure of sunlight/energy which is a factor in the dragonfly habitat.
Any insight or suggestions are greatly appreciated.
Thank you,
Darcy
Not directly, you have to make assumptions about the wavelength range and source.
Lux is lumens/m^2, Lumen is the power on the surface but adjusted for the response of the eye.
Sunlight is about 90lumens/watt
ok, Thank you.
I don't think I explained that very well.
Lux is the unit of ilumination = power / area
So 1 lux is 1 lumen / m^2, and daylight is about 30,000-100,000 lux or 30-100 Kl/m^2
Lumens are normally used with artificual light sources to compare how much light you get out for a certain power in - that's because you can't compare the light output of a 1Watt LED and a 60W light bulb form their power.
Sunlight's efficency is about 90lm/watt so 90,000 lux is 90,000 lm/m^2 = 1000W/m^2
You said your model was in KJ/m^2, presumably this is per second (Joules are a measure of energy not power) so KJ/m^2/s = kW/m^2
Ok, that is perfectly clear...thank you again!
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of...
