nazmulhasanshipon
- 40
- 3
- Homework Statement
- If in both an [*isobaric*](https://en.wikipedia.org/wiki/Isobaric_process) and [isothermal](https://en.wikipedia.org/wiki/Isothermal_process) process, the volume of one gram hydrogen gas (which is evidently by the formula ##n=\frac{m}{M}## is ##0.5## mole) is expanded ##4## times the original volume then calculate the change in entropy in the two thermodynamic process and also compare the two change in entropy mathematically.
- Relevant Equations
- Second law of Thermodynamics, Entropy, Isobaric Process, Isothermal Process
Upon seeing the question in my assignment I knew in a isobaric process, work done by the gas is ##W=P\Delta V## so if volume is increased ##4## times the original considering the original volume as ##V## we can say after expansion the volume is ##4V##. Then ##W=P(4V-V)=3PV## and the ##Q## would be ##Q=\Delta U +3PV## but I don't know how to go from here all the way to comparison. Also upon searching in the web I found [this](https://chem.libretexts.org/Bookshelves/Physical_and_Theoretical_Chemistry_Textbook_Maps/Book%3A_Physical_Chemistry_(Fleming)/05%3A_The_Second_Law/5.04%3A_Calculating_Entropy_Changes) which is helpful but for the isobaric process I don't know anything of the temperature ##T##. I am very much confused here. Any help will be appreciated.
