Complex Analysis: Cauchy Riemann Equations 2
In summary, Theorem 1 states that if a function is complex differentiable at one point, then it has partial derivatives at this point and these partial derivatives satisfy the Cauchy-Riemann equations. Theorem 2 states that if the partial derivatives of a complex function exist and are continuous in a domain, then the function is analytic in that domain. These two theorems can be combined into an "if and only if" statement, where a function is analytic in a domain if and only if the partial derivatives exist, are continuous in the domain, and satisfy the Cauchy-Riemann equations. However, some authors prefer to emphasize that complex differentiability at one point implies the Cauchy-Riemann equations at
Darth Frodo
212
Hi All,
I was reading through Kreyzeig's Advanced Engineering Mathematics and came across two theorems in Complex Analysis.
Theorem 1:
Let f(z) = u(x,y) + iv(x,y) be defined and continuous in some neighborhood of a point z = x+iy and differentiable at z itself.
Then, at that point, the first-order partial derivatives of u and v exist and satisfy the Cauchy–Riemann equations.
Theorem 2:
If two real-valued continuous functions and of two real variables x and y have continuous first partial derivatives that satisfy the Cauchy–Riemann equations in some domain D.
Then the complex function is analytic in D.
It seems that the hypothesis of Theorem 1 is similar to the conclusion of Theorem 2. Can these two theorems be modified into one iff statement?
Thanks.
Theorem 1 states that if a function is complex differentiable at one point, then it has partial derivatives at this point, and these partial derivatives satisfy Cauchy--Riemann equations. BTW, continuity of ##f## in a neighborhood of ##z## is not needed in Theorem 1, ##f## only needs to be defined there and to be complex differentiable at the point ##z##. The proof is very easy, just a trivial computation.
Theorem 2 says that if partial derivatives exist and continuous in a domain ##D##, then the function is analytic in this domain.
Of course, one can say that a function is analytic in a domain if and only if the partial derivatives exist, are continuous in the domain and satisfy the Cauchy--Riemann equations there; this is a true theorem. But many authors like to emphasize that complex differentiability at one point implies the Cauchy--Riemann equations at this point.
I think the standard example of differentiable but not analytic is ## f(z)=|z| ; |z|:= (x^2+ y^2)^{1/2} ; z=x+iy ##
Related to Complex Analysis: Cauchy Riemann Equations 2
1. What are the Cauchy-Riemann equations?
The Cauchy-Riemann equations are a set of two partial differential equations that describe the analyticity of a function in the complex plane. They relate the real and imaginary parts of a complex function and are used to determine if a function is holomorphic (analytic) or not.
2. What is the significance of the Cauchy-Riemann equations in complex analysis?
The Cauchy-Riemann equations are essential in complex analysis as they provide a necessary and sufficient condition for a function to be analytic. This means that if a function satisfies these equations, it is guaranteed to be differentiable at every point in the complex plane and can be expanded into a Taylor series.
3. How are the Cauchy-Riemann equations derived?
The Cauchy-Riemann equations can be derived from the definition of complex differentiability, which states that a function is differentiable if the limit of its difference quotient exists. By substituting the complex variable z = x + iy into this definition and equating the real and imaginary parts of the resulting equation, the Cauchy-Riemann equations can be obtained.
4. Can the Cauchy-Riemann equations be used to prove the analyticity of a function?
Yes, the Cauchy-Riemann equations can be used to prove the analyticity of a function. If a function satisfies these equations and is continuous, it is guaranteed to be analytic. However, the converse is not always true, as a function can be analytic without satisfying the Cauchy-Riemann equations.
5. Are the Cauchy-Riemann equations applicable to all functions in the complex plane?
No, the Cauchy-Riemann equations are only applicable to functions that are differentiable at every point in the complex plane. This means that the function must have continuous partial derivatives with respect to both x and y. If a function does not satisfy these criteria, the Cauchy-Riemann equations cannot be used to determine its analyticity.
  • Topology and Analysis
