Complex analysis: Find a function that maps z1 and z2 onto w1 and w2
Juwane
What is the function (linear transformation) that maps z_{1} = 2 and z_{2} = -3i onto w_{1} = 1+i and w_{2} = 3?
I think it's asking for the function that if you put 2 in it, it should give 1+i, and if you put -3i in the same function, it should give 3.
The answer given at the back of the book is w=f(z)=\frac{3+2i}{13}z + \frac{7+9i}{13}
Maybe these would help:
x = \frac{z + \overline{z} }{2} and y = \frac{z - \overline{z} }{2i}
I have no idea how to even start. The horrible book I am using doesn't give a clue. One possible way is to see what do we have to z_{1} = 2 to get 1+i. The answer is: -1+i , but we can't add this to z_{2} = -3i, since that would give us 1-2i whereas we must get 3. Is there any other way to find out?
The textbook's answer gives f(z) as a linear polynomial with complex coefficients, which is one way to represent this function. It gives the right results for the two given complex numbers.
Edit: Scratch part of what I said. The formula gives the right result for 2 + i, but not the right result for -3i.
Another way to approach this problem is to use linear transformations, and treat complex numbers as vectors in R2.
From the given information, T(2) = T(<2, 0>T) = <1, 1>T, and
T(-3i) = T(<0, -3>T) = <3, 0>T.
Using the properties of linear transformations, it's easy to find T(<1, 0>T) and T(<0, 1>T). That means that you can find T(a + bi) = T(<a, b>T) = aT(<1, 0>T) + bT(<0, 1>T), for any complex number a + bi.
I think you mean w2=1. Double check the book. A linear function is f(z)=a*z+b for complex constants a and b. Just put in the given values and solve the two simultaneous equations for a and b.
Dick is right. If w2 is 3, then the formula given as an answer is wrong.
Yes, you're right. w2 is 1, not 3. I'll try to use the method you've given here. Thanks.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
