Complex Analysis - Solving Complex Trig functions
NewtonianAlch
Now, I know there's two ways to go about this and it seems everywhere I look around on the web people are solving it in a way I think that seems longer, harder and more prone to mistakes in exams. It involves using the exponential identities and taking logs. I was shown another way, but unfortunately I haven't quite got the grasp of it.
sinh z = 0
sinh (x + iy) = sinh(x)cos(y) + i cosh(x)sin(y) = 0
So
1) sinh(x)cos(y) = 0
2) cosh(x)sin(y) = 0
(1) Either x = 0 or y = ± Pi/2
(2) cosh (x) is never 0, so therefore x is not 0. Hence y = 0
This is where I'm stuck, I do not know how to go from here.
The answer is z = i*k*Pi
You have two simultaneous equations. You've correctly deduced that cosh(x) is never 0, so therefore in equation 2 divide both sides by cosh(x) to get
sin(y) = 0
which occurs when y = k*Pi, where k is an element of the integer set
Ok so we now know y! Let's look at x. Now you use your first equation:
at y = k*Pi, cos(y) = 1 or -1
so divide both sides by cos(y) and get
sinh(x) = 0, therefore x = 0
so what we have is z = x + iy = i * k * Pi.
This method is a lot more simple, it just involves working through the simultaneous equations carefully. Where you started to go wrong was when you assumed y just has to equal 0, rather than the general solution of k * Pi
Hmm, interesting. I think I'm starting to see it now.
So suppose I have cosh z = 1
cosh (x + iy) = cosh(x)cos(y) + i sinh(x)sin(y) = 1
cosh(x)cos(y) = 1
sinh(x)sin(y) = 0
cosh(x) = 1 only when x = 0, and cos (y) = 1 for 2*k*Pi
So now we already have values for x and y, substituting this into the imaginary component, validates that.
So z = i*2*k*Pi
Is my reasoning correct? Thank you for your help by the way.
Stuck again now!
cosh z = 2i
I posted this question earlier but back then I only knew the exponential and log method.
What I've got so far:
cos (x + iy) = cosh(x)cos(y) + i sinh(x)sin(y) = 2i
1) cosh(x)cos(y) = 0
2) sinh(x)sin(y) = 2i
From equation 1, cosh x cannot be zero. For cos (y) = 0, y is periodic so y = (Pi/2 + kPi)
Now this is where I'm stuck on how to deal with that in equation 2.
The final answer given is (-1)^k arcsinh(2) + i(kPi +Pi/2)
I can see how that answer for y I got in equation 1 has something to do with the final answer.
Edit:
I'm thinking that if y = (Pi/2 + kPi), this would mean sin(y) = (-1)^k
So dividing sin (y) in equation 2, we get sinh(x) = (-1)k 2i
Taking arcsinh of this now means arcsinh((-1)^k 2i)
Does this mean I can take out the (-1)^k ? I still haven't figured out what to do with the i hanging around.
That's true but cosh(x) cos(y) = 1 holds for other values as well, for example cosh(x)=2, cos(y) = 1/2.
that should be 2, not 2i
That would explain it then, thanks!
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
