Complex impedance and negative reactance
The circuit analysis involves a voltage of v(t) = 100cos(ωt) and a current of i(t) = 2cos(ωt + π/3). The calculated impedance is Z = 46 - j19, indicating a negative imaginary part. This suggests that the circuit has more capacitive reactance than inductive reactance, but it does not provide enough information to determine if only capacitors are present. The conclusion is that while the negative reactance indicates capacitive dominance, the exact configuration of components remains unclear.
eng_stud
consider a circuit expressed by v(t)= 100cos \omega t
and i(t)=2cos(\omega t+\pi / 3) .
Find the reactance.
Z=\frac{V}{I} = R+jX
Z=\frac{100}{2\angle \pi /3} = 50\angle -\pi /3 = 46 - j19
Does the negative imaginary part mean there is simply more reactance from the capacitor than inductor? Or *only* cap?
thanks!
There is not sufficient information to find if there is only capacitor or there is more capacitive inductance than inductive.
That makes sense, thank you!
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
