Complex Integrals (for me at least)
In summary: Hey!You might try using \log x^a = a\log x, and re-write it in the equivalent form\int t\log\sqrt{1+t}\, dt = \frac{1}{2}\, \int t\log(1+t)\, dt
filiphenrique
Hey!
How do I integrate ∫tln√(t+1) and ∫4te^(2-0,3t)?
Thanks in advance.
On that first integral, you might try using \(\displaystyle \log x^a = a\log x\), and re-write it in the equivalent form\(\displaystyle \int t\log\sqrt{1+t}\, dt = \frac{1}{2}\, \int t\log(1+t)\, dt\)
Next, try the substitution \(\displaystyle y=1+t?\)NOTE: I always use "log" instead of "ln", so where you wrote "ln" I've written "log".
For the second integral, I'm not entirely sure what you mean. Is it
\(\displaystyle 4\, \int e^{2-0.3 t} \, dt = ?\)
If so, then it might be worth separating the exponential term into two parts; one that contains the variable "t", and must - therefore - be kept inside the integral sign, while the other is a constant \(\displaystyle (e^{x+y}=e^xe^y)\):
\(\displaystyle \int e^{2-0.3 t}\, dt = e^2\, \int e^{-0.3 t}\, dt\)
Hello, filiphenrique!
Integrate these "by parts".
I'll do the first one.
[tex]I \;=\;\int t \ln\sqrt{t+1}\,dt[/tex]
[tex]\begin{Bmatrix}u &=& \tfrac{1}{2}\ln(t+1) && dv &=& t\,dt \\ du &=& \tfrac{dt}{2(t+1)} && v &=& \tfrac{1}{2}t^2\end{Bmatrix}[/tex]
[tex]I \;=\;\tfrac{1}{4}t^2\ln(t+1) - \tfrac{1}{4}\int \frac{t^2}{t+1}\,dt [/tex]
[tex]I \;=\;\tfrac{1}{4}t^2\ln(t+1) - \tfrac{1}{4}\int\left(t - 1 + \frac{1}{t+1}\right)\,dt[/tex]
[tex]I \;=\;\tfrac{1}{4}t^2\ln(t+1) - \tfrac{1}{4}\left[\tfrac{1}{2}t^2 - t + \ln(t+1)\right] + C[/tex]
[tex]I \;=\;\tfrac{1}{4}t^2\ln(t+1) - \tfrac{1}{8}t^2 + \tfrac{1}{4}t - \tfrac{1}{4}\ln(t+1) + C[/tex]
Hey, thanks for the reply. I got what you meant in the first integral I posted. But in the second integral, We really have the t variable before the e^(2-0,3t). Based on the way you start solving the integral, can I put the 4 and the e^2 off and integrate te^0,3t by parts? Thanks!
- - - Updated - - -
By the way, how do I write integrals the way you guys do here?
Hiya! :D
Yes, you certainly can integrate that last one by parts, starting with \(\displaystyle (d/dt)e^{at} = ?\)
To show integrals the way I posted above, write
to display as
\(\displaystyle \int f(x)\, dx = g(x) \)
And as for the integral itself, if \(\displaystyle a\) and \(\displaystyle b\) are constants, then
\(\displaystyle \int e^{a+bx}\,dx = \int (e^a\, e^{bx})\, dx = e^a\int e^{bx}\, dx\)
Can you solve it from there? :D
FAQ: Complex Integrals (for me at least)
What are complex integrals?
Complex integrals are integrals that involve complex numbers. They are used to calculate the area under a curve on the complex plane.
How are complex integrals different from real integrals?
Complex integrals involve integration over a complex variable, whereas real integrals involve integration over a real variable. Additionally, complex integrals take into account the imaginary part of the function being integrated, while real integrals only consider the real part.
What is the Cauchy Integral Theorem?
The Cauchy Integral Theorem states that if a function is continuous and differentiable in a closed contour, then the integral of that function around the contour is equal to 0.
How are complex integrals used in physics and engineering?
Complex integrals are used in physics and engineering to solve problems involving electric and magnetic fields, fluid flow, and heat transfer. They are also used in signal processing and control systems.
What is the Cauchy Residue Theorem?
The Cauchy Residue Theorem states that if a function is analytic within a region except for isolated singular points, then the integral of that function around a closed contour is equal to the sum of the residues of the singular points inside the contour.
