Complex Variables Algebra Solutions / Argument/Modulus
gbu
Solve for a, a \in \mathbb{C}
<br /> \frac{2\ln(a^2 - 1)}{\pi i} = 1<br />
N/A.
Reorganizing the equation.
2\log(a^2 - 1) = \pi i
<br /> \frac{2\log(a^2 - 1)}{\pi i} = 1<br />
N/A.
Expanding the logarithm.
2\ln(|a^2 - 1|) + i \textrm{arg}(a^2 - 1) = \pi iI think what I'm stuck on is that I don't know how to evaluate my length/argument of an arbitrary complex variable like that. I know how to solve them if I'm given a value of a (a = x + iy, then |a| = \sqrt(x^2 + y^2) and arg(a) = \tan^{-1} \frac{y}{x}), but without the value of a I'm not sure where to go.
so a = x+yi. Then (x+yi)^2-1 = (x^2-y^2-1)+2xyi. What is the modulus of that?
Put your i's together as well.
It's
<br /> \sqrt{(4x^2 y^2 + (x^2-y^2-1)^2)}<br />
Which I suppose gets me to an answer, but its certainly not a pretty one. Wolfram Alpha gives a very simple answer to the question (a^2 = sqrt(1+i))
gbu said:
It's
There may be a better way to do this one. Let me think.
Separate to log = pi i/2 and raise use the inverse function e.
Look at what the parts of
2\ln(|a^2 - 1|) + 2 i \arg(a^2 - 1) = \pi i
are telling you. Equate real and imaginary parts, so \ln(|a^2-1|)=0 and \arg(a^2 - 1)= \frac{\pi}{2}. Without solving any equations and just thinking geometrically, what do those two things tell you about a^2-1?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
